RV.Net Open Roads Forum: Tow Vehicles: F-450 6.4psd Fuel Mileage
Search only in Tow Vehicles
 > F-450 6.4psd Fuel Mileage
legsnred
Prosser Wash
Posted: 05/18/08 11:26am Link  |  Quote  |  Print  |  Notify Moderator
What kind of mileage are you getting towing with the new 6.4?
:,)2003 F-350 4X4 PSD 2006 Everest 344J
G & G Shelton
North Central Florida
Posted: 05/18/08 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
I get 11-13 running around town with no 5'er. I get 6-7 with the trailer on the highway.
BUT, I have the heavy tow package with the 4.88 rear end so that is what does me the most harm.
2007 Raptor 3712TS Toy Hauler
2008 F-450 Lariat W/ Lots-o-Options (Became mine on 2/22/2007)
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/18/08 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Those trucks should come with a double overdrive gear as a factory option, or a 2-speed rear axle.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
jauguston
Bellingham, WA
Posted: 05/18/08 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
Why??
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
wcjeep
Tacoma, Wa
Posted: 05/18/08 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
I was reading elsewhere a few months ago the 6.4l Ford Diesel has a maintenance schedule for the exhaust system. Ford recommends replacing the entire exhaust system at 120,000 miles to the cost of $4,000.
G & G Shelton
Posted: 05/18/08 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
I agree. I have looked at a Gear Vendor overdrive, but I just don't know if I want to make the investment being I don't really drive the beast if I am not towing.
It is the DPF that will eventually need to be replaced, but they have already come up with a way to clean them.
BTW: It is not $4k either. It is like $1200.
Jwmoehrle
philadelphia, PA
Posted: 05/18/08 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Thats good to hear at about 100,000 miles, I plan to just do, that.
Not@Work
Chesapeake, VA
Posted: 05/19/08 04:55am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2008 F-450 4WD with the HD tow package (4:88 gears) also. My truck is a Job #1 build and it has approximately 11,000 miles on it now. When I used to use it as my daily driver, if I stayed right around 55 mph I was able to get just under 13 mpg by hand calculation, not the lie-0-meter. We recently purchased rig in my signature and so far I figure it is getting around 7 mpg towing the TH. One thing I am going to try, is replacing the front air dam under the front bumper. According to some of the diesel forums, if Job #1 owners switch to a Job #2 air dam (which is significantly longer) it is supposed to smooth out the airflow under the truck and some have seen improvements as much as 0.5 to a little over 1 mpg. Well worth the $100 or so dollars that it costs if that is true. I will be ordering mine this week. Hope this helps.
2008 Ford F-450 XLT Lariat 4WD w/ 4.88's
2008 Keystone Fuzion 393 (Fire interior, 2nd A/C, all options
2007 Harley Davidson Screamin' Eagle Softail Springer
2007 Harley Davidson Sportster XL883 Low
Wife, Daughter, Son, and Harley (the Toy Rat Terrier)
mhend12
Baltimore Md
Posted: 05/22/08 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Not the whole just one particular part. Cannot spit the name of the part out right now. Just went to 6.4 class last week. Its not that big of a part but it is about 1200.00 and a real pain to install. Ill get the name of the part tommorow. I'll try anyway.
Mike and Alicia and Penny and Poppy the shelties
06 F350 CC Long bed 6.0
04 Laredo 29GS
RMB
Denham Springs La.
Posted: 05/22/08 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Tow 5th wheel in profile no matter how much weight I put in, gets 7.5 mpg. Also have new 7x16 v-nose enclosed trailer for other toys about 4000 pounds gvwr. 9.5 mpg. Empty, about 13 hwy. 11+ city. Job 2 truck (10-07) 9000 miles 430 rear end. Not cheap but a great tow vehicle. Hope this helps!
  • 2008 Ford F-450 XL Crew Cab 4X4
  • 2006 Coachman Adrenaline 400DS Toy Hauler
