RV.Net Open Roads Forum: Tech Issues: help me find a capacitor
 > help me find a capacitor
snowman610
Winona MN
Posted: 05/18/08 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
I need a soft start capacitor for a carrier air V 13500 unit. What is the best place online to order one?
Thanks! my dogs will thank you too if I can get this to work with my genset.
2008 FleetwoodE4
2005 F-150 with mods
2006 Can-Am Outlander Max
Winona,MN
USAFBILL
Alabama
Posted: 05/18/08 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
Might pick one up at Lowes or Home Depot.
rv2go
Somewhere between Knoxville, TN and the coast.
Posted: 05/18/08 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
See if this site will address your needs.
Winnebago Journey
TN Lic. RV 2 GO
1995 2dr. Hard Top Geo Tracker
www.rv2go.us
I'm here #4335
Travel Photos
Fiverwheel
Southern CA
Posted: 05/18/08 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Supco is the best supplier as far as I know.
"Blewbyou"
2002 26.5 MB Lazy Daze
CJW8
Arizona
Posted: 05/18/08 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a down side to using Compressor Hard Start Boosters?
2004 F350 PSD FX4 SB CC, Banks Cold Air Intake
18,000 Superglide
2003 37SP Forest River Sierra Toyhauler
2008 Polaris RZR
javaseuf
Southern Cal
Posted: 05/18/08 11:30pm Link  |  Quote  |  Print  |  Notify Moderator
What is a "soft-start" capacitor. I sell caps and hard-starts where I work but never heard the term "soft-start".
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
weissmand
Los Angeles, CA
Posted: 05/19/08 12:04am Link  |  Quote  |  Print  |  Notify Moderator
RV2Go is right, ArnoldService is the best. I ended up going to the Supco's webpage supco.com and used the distributor page to find a local distributor who had it in stock. It was a few dollars more, but I got it right away. Gotta love instant gratification!
CJW8, to answer our question, is it bad? that's a loaded question and I'm sure to get flamed for it, but No would be the answer I would give; However, I'll qualify it. If you're connected to a 30 amp outlet and you're 20' away from the connection post, then the "hard start" won't help you; However, if you're running a generator and you have enough amps to run it but not enough to start it, then the hard start will overcome the initial inrush of current that's delayed because your generator isn't putting it all out. Thus, you're giving the compressor more current than it needs to overcome the compression. It's bad if you're generator can't sustain the needed power to run the AC because the hard start will provide additional current that the compressor isn't designed to absorb and premature wear out the compressor motors windings.
javaseuf I believe it's a misnomer that it's a soft start or a hard start. It's a start capacitor period. While there's a capacitor in built into the unit, I think it's only designed with enough Microfarads to turn the unit over assuming you're connected to AC. I know that Hard Start capacitors refer to motors that are old and are hard to start and are at the end of life. I guess the concept of Soft Start is for a functioning motor, but it needs a little soft push to get it going? I don't know! LOL I guess it's the same as a Hot Water Heater. If the water is hot, why do you need to heat it?
josh
rob85546
Hot arizona
Posted: 05/19/08 02:30am Link  |  Quote  |  Print  |  Notify Moderator
thats what I got... the local ac shop for 20 bucks
2007 GMC DURAMAX,LBZ,4 by Crew, Allison
Magnaflow Turbo Back Exhaust
Predator Tuner
18by9 Helo's on BFG's
5year old boy
3 year old baby girl
Sea ray boat
Wilderness 5th wheel
SandRail
HD WideGlide
FORD Expediton
honda Eu3000
snowman610
Winona MN
Posted: 05/19/08 06:17am Link  |  Quote  |  Print  |  Notify Moderator
thanks RV2GO ! thats what I was looking for. Its worth $30 to keep it cool!
BaldEagle
Oregon
Posted: 05/19/08 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Supco is a wholesale distributor requiring an account and usually has a $100 minimum order. You can go to their web site and they will direct you to a retailer.
2004 Vectra 40AD
2002 MDX Toad/Brake Buddy
Roadmaster Blackhawk
Guardian Rock Shield
