topwop39
Akron,Ohio
What's the best location on the 5er to check for level side to side. Brought my new 5er home yesterday from storage and checked for level on the kingpin and on the rear bumper. After placing boards under appropriate tires and bubble showing level, I extended slide out. Just to double check I placed level on counter and bubble was off. Where do you all place your level?
Thanks.
2004 Chevy Silverado 2500 4x4 crew cab
2007 Coachman Chaparral 269 BHS 5'er
prodigy brake controller, pullrite 14K superglide
Akron Fire Local 330
tvman44
Southwest Louisiana
I put a 4' level on the floor in the middle of the trailer.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
AVid
SE Michigan
Did you put the rear stabilizer down before your extended the slider? If not, the weight of the slider hanging off the side of the fiver will cause it to list to that side by a small amount.
AVid
Fiverwheel
Southern CA
I think that on all RV's the goal is to get the refrigerator level and then to get the rest of the coach level. This is not as critical with the newer units but should be a consideration. That being said, a level placed on the floor (as stated above) is about as good as you can do.
"Blewbyou"
2002 26.5 MB Lazy Daze
Texlawdawg718
Longview, Texas
I leveled out with a four foot level and then I put some stickers on the side of my rig by my landing gear switch. That way I know when I'm level right by my jacks. My other level is underneath.
hotrod4x5
Fulltiming Southwest USA
I also place a level on the floor in the middle, which happens to be right where my entrance door is.
Rodney 2005 Laredo 29GS 2002 F250 V-10 Hughesnet Satellite Internet
Cheddarhead
Northern Wisconsin
I level my kitchen counter top. Hard to make omelettes when that's out of whack. that makes it close enogh for the rest of the rig.
2006 Chevy 2500HD EC/SB 4x4 Duramax/Allison
05 Jayco "Jayflight" 285RLS
Some of our trip Pics
Bill1374
Saratoga Springs, NY
Sounds normal to me. Over many TTs and fifths, I've found that the floor, fridge and counter are not necessarily level at the same time. My choice has allways been to level the fridge and counter, splitting the difference if necessary.
Bill
2000 Hitchhiker II Rio Grande
2000 Dodge 3500 dually Cummins 5 speed Edge EZ and guages
rowaltonjr
Castle Hayne, NC
I installed our level guage using a 4' level on the floor & it's right on. Always put your rear jacks down before putting the slide out. I find that I have to also go back & put a half turn or so on the off slide side jack after putting the slide out.
nogo
2004 2500 Sierra, 2006 Keystone-Cougar 291EFS 5th wheel
We don't do anything, but we do it real well
RV camped in 49 states, every province & territory of Canada & 2/3 0f Mexico
N9MB
Indiana
I put the level inside the door, level side to side, drop the landing gear, disconnect and level front to rear then lower the rear stabs.
