RV.Net Open Roads Forum: Tech Issues: Decent 12v coffee maker???
 > Decent 12v coffee maker???
Page of 6
Hurricaner
Hurricane Utah
Posted: 05/20/08 11:13am Link  |  Quote  |  Print  |  Notify Moderator
I don't get the 'unleaded gasoline' description on the Coleman. Is there LEADED gasoline ANYWHERE?
Probably not but these things have been around a long time and when they first came out there was, so the name stuck.
It also prevents confusion as Coleman fuel is also known as white gas. This is the preferred fuel as it burns cleaner and hotter but I have burned unleaded in mine and it works fine although more maintenance is required.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
Tress
Virginia
Posted: 05/20/08 11:58am Link  |  Quote  |  Print  |  Notify Moderator
Sam
So i take you own one of these Exponent Feather's? How are they, does the gas leak at all or is the container tight? How about eficiency? How long does it work on one tank? And finally how much does that lil tank hold? Sorry but i couldn't find much info on the Coleman site... thanks again... oh one other thing, do you know what the diff between these two
eferralID=423124cc-26a2-11dd-990b-000423bb4e79">Feather
Sportster
* This post was edited 05/20/08 01:24pm by Tress *
mikeinboise
boise
Posted: 05/20/08 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
I have used a coleman over the stove drip coffee maker, then a french press, now I just take instant coffee with me! Sure, its not as tasty as fresh ground but I just want to keep things easy and simple and a spoon of instant in hot water is about as simple as you can get!
1998 Four Winds 5000 21RB Chevy "Sonoran Flyer"
2006 Springdale 179RD - SOLD
2004 FORD F-150 SuperCrew 4x4 5.4L
1999 Voyager 21' Pontoon Boat
2007 Kipor KGE1000ti
2007 Champion C46540 RV Generator
vermilye
Oswego, NY, USA
Posted: 05/20/08 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
I'll second the use of the Coleman white gas stove & a Melita drip cone into a thermos. I am far too picky about my morning cup - When tent camping I still carried whole beans, ground them using an inverter for power, and the one burner stove to boil the water. Worked great, fast, and simple.
Jon Vermilye Travel & Photo Web Pages ... My Collection of RV Blogs & Journals
Lake McDonald, Glacier National Park, MT
stevenal
Newport, OR, USA
Posted: 05/20/08 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
Tress wrote:
How about efficiency? ...
Certainly not as efficient as electric, since not all the chemical energy in the gasoline is converted. And not all the heat produced is going into the coffee. Most of the heat produced is being used to evaporate the moisture produced during combustion, and to warm and move the surrounding air. Not sure why the focus on efficiency, though. Most of us look more at cost and energy density and availability.
'99 Bigfoot 1500
with low loss control on the Fantastic, Dino board on the Dometic.
Torklifts and Fastguns
'04 F350 V10 Crew SRW SB 4X4 6 speed
with tow hook replacement, dual rate charging, Line-X, Timbrens.
Tress
Virginia
Posted: 05/20/08 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
Im pretty sure this is my word, a decent cup is crucial, especially since ill be in some areas with fantastic bean
Tress
Virginia
Posted: 05/20/08 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
The focus on efficiency is because im going to be living out of a van for over 1.5 years in Central and South America. Propane is NOT readily available and i only have so much battery power so electricity is a minimally available. In other words the goal is to have a vehicle that can dry camp for as long as possible without using the engine so efficiency is very important....
* This post was edited 05/20/08 02:13pm by Tress *
pnichols
Santa Cruz Mountains
Posted: 05/20/08 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
"MRP Coffee.... hmmm sounds convenient, but perhaps not very tasty..."
Nothing to do with MRP rations! Only the TECHNOLOGY came from the military.
These heated coffees for the commercial market started out "Back East" in the US or Europe, I believe, for the yuppy/way busy/Starbuck get-it-in-a hurry group at about $4 each. Now I think they may be available nationwide for way less, $2 each on down perhaps.
Great for day hikes and "reasonably short" RV trips where the idea is to not cook at all, or much at all. (Like us on some short RV jaunts.)
Phil, 2005 E450 Itasca 324V Spirit
Wherever I happen to park
Posted: 05/20/08 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
I just run a 120 volt coffee maker off an inverter
Someone said
Maybe they are 100% efficient when it comes to using power, but as for creating heat to make coffee hot, it would seem there is an efficiency factor.....
The difference is not in making heat, as noted resistance heaters, at least SPACE heaters, are 100% efficient, A coffee maker might b 99.9% but there is some loss in the power cord and plug so it's not quite 100.
The difference is in keeping the coffee hot.. In days of old it was often a stainless steel container... Today it's often something with an R-Factor much greater than ZERO. (Heat transfer resistance factor)
in the case of a 12 volt coffee maker..Due to the fairly stiff current load. Losses in the wires and power cord add up fast.. Thus I suspect my use of the 120 volt device powered by the Prosine 2.0.. Is more efficient Much more.. Due to power cord losses being 10% of what they are in a 12 volt job
DaveMac
Citrus Heights, CA, USA
Posted: 05/21/08 12:08am Link  |  Quote  |  Print  |  Notify Moderator
Why not hang a Black & Decker auto coffee maker under the counter and fire up the genny when you want coffee. That's my setup and when on hookups you can set it to make coffee at any time in the morning.
2007 FIESTA LX
TRITON V-10 & JEEP LIBERTY TOAD
3 TIMES RETIRED
CH. 13 "BLACKJACK"
Page of 6
