FF1063
LI, NY
I seem to have lost my ABS on my truck, I noticed the amber 'ABS' and the red 'Brake' warnings on the dash turned on while driving.
Brakes are good, just no more ABS. I did notice now when I turn the start key to 'on', I no longer hear the typical 'clunk' sound which I now realize was part of the ABS selftest.
Any ideas before I end up at the dealer ? Fuses are good, all sensor wiring appears OK.
Thanks
AF 990 / DRW 3500
SteveB
Rhode Island
Is your speedo working correctly? The easy cause could be the speed sensor in the rear end housing. Beyond that, a code reader may be needed.
SteveB
'01 Dodge Ram 3500 CTD HO 6sp, Reese 15K Pro w/ Kwik Slide, Prodigy
'04 Jayco Jayflight 28.5RKS
pulsar
Lewisville, NC
Moved from Technology Corner to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
dsolberg
Midwest
According to several Dodge forums (googled '98 CDT 3500 Ram No ABS) it seems the wheel sensors are a common problem with this vehicle. I would suggest taking it to a qualified service center that can read the "code" and find out what it is. I had a 2000 VW Passat (I think they missed a few letters in this name!) and had several check engine lights, or what I called the "$500" light come on as well as the ABS light twice! After replacing the first $500 module, the next time I took it to the VW dealer which was the only place that could read a VW code and paid them $90 to hook it up and give me the code. I then went on-line and found the second and third $500 module for $75 and $150 both with a 5 year warranty. The dealer wanted $500 and only a 90 day warranty. When the ABS light came on, once again, $90 indicated is was an ABS Vacuum module block and they wanted $1500! I found a remanufactured one for $150 guaranteed for 5 years and put it in myself. Get an estimate...search the Dodge forums.
ScottG
Bothell Wa.
The sensor in the rear end is a common failure on that vintage of Dodge.
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
donn0128
Pronounced Ore-gun
Your in the rust bely. Wheel sensor is bad?!
Donn
FF1063
LI, NY
Thanks for the replies and info. Yes, my speedo is fine, I'm aware that the rear sensor is common from another forum, I physically checked the connection, but could not do more than that. It seems as if the C.A.B. controller is just dead, and I did not think that would be caused by a single wheel sensor alone (I no longer have that 'Thump' sound, I took the C.A.B off and I can clearly see six electro-mechanical type solenoids inside, I think that's where the thump comes from during self-test)
I will probably buy a DRB scan tool and read the stored code so I'll have a heads up on the dealer. If it's the C.A.B, I can't just replace it because it needs to be programmed for my truck first, I know these problems can be costly.
Thanks again to all, I'll post the fix after I find it.
FF1063
LI, NY
ScottG wrote: The sensor in the rear end is a common failure on that vintage of Dodge.
Donn / Scott
If the rear sensor failed, would'nt the speedo no longer work ?
Piney Boy
TN
My 2000 did the same thing and it was the rear speed sensor. Very easy to change.
FF1063
LI, NY
Update:
Replaced the rear wheel speed sensor, $47 from Dodge. Problem solved.
Thanks for the replies.
