RV.Net Open Roads Forum: Tech Issues: Conflicting info for Jayco and Dealer
 > Conflicting info for Jayco and Dealer
sagexpman
Loveland, Colorado
Posted: 05/19/08 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have 12 volt cigarette lighter type outlet that is located next to the 120 volt AC outlet in the entertainment center area for the TV and DVD player in my 2005 Jayco 31BHS. What I want to do is plug a 500 watt inverting into the cig outlet and then plug my TV and DVD players into the inverter when dry camping. I called Jayco and they told me that this would damage the wiring in the TT and not to do it. Two Jayco dealers have told me that this would not be a problem.
Are there any Jayco owners out there that have any experience with what I am trying to do? If so I would love to hear from you. I do not want to try it and fry something in the TT.
Thanks, Rick
1998 HD Chevy Silverado 2500
- Super Charged Vortec 5.7
- Air Lift Suspension System
- Drawtite WD hitch with 1200# bars
- Drawtite DC sway control
- Honda EU3000IS
2005 Jayco JayFlight 31BHS
John & Angela
Full Timers in Canada, USA and Mexico
Posted: 05/19/08 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
Good afternoon.
In my humble opinion 500 watts or even 350 watts is too much to pull from a cigarrette lighter adaptor and the probable 12 gauge wire feeding it. I suspect the voltage drop would more than likely be too much to hold the inverter on anyway. You may want to consider a proper inverter install and either dedicated circuit or additional circuit install from it.
JMHO
Come visit us at our website and share in our great fulltime RV Adventure.
2003 Fleetwood Revolution 40C
Retired Canadian Air Force Technicians
Vernon,B.C,Canada.
SteveB
Rhode Island
Posted: 05/19/08 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Rick,
I think that a 500 watt load at 12VDC is about 40 amps. It is only 4.2 amps at 120V. It is not a direct translation from DC to AC though.
None of the 500 watt units that I've seen has a cig plug but a couple of direct wire terminals.
That could be why Jayco is advising against it.
SteveB
'01 Dodge Ram 3500 CTD HO 6sp, Reese 15K Pro w/ Kwik Slide, Prodigy
'04 Jayco Jayflight 28.5RKS
tvman44
Southwest Louisiana
Posted: 05/19/08 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
12 gauge wire is rated at 20 amps, 500 watts at 12 volts is about 41amps. Do the math.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
mike4947
N. Syracuse, NY
Posted: 05/19/08 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
To add to those siding with the factory. Plastic 12 volt outlets are rated for 8 amps and fused for 7.5 amps. That's 90 watts.
Metal Cigarette lighter outlets are rated and usually fused for 20 amps. That's 240 watts.
We've scrapped many a mess of molten plastic and replaced scorched wood from over loaded unfused 12 volt outlets.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
mark1228
Helena, MT
Posted: 05/19/08 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
I will argue the other way. I have the same set up in my Maverick motorhome and I put in an inverter that plugs into the 12 volt plug for my 26" flat screen and DVD player just like you are thinking of doing. My inverter has a gauge that shows the draw and with both the TV and DVD player on and running, it is pulling under 100 watts, even though it is a 400 watt continous/800 watt peak inverter. The key is to not overload it. You cant run your coffee pot or blow dryer off of that wiring, but TV and DVD don't draw much.
Almost every manufacturer puts that plug (Winegard) in their entertainment center and I have also run a 9" TV/VCR combo off of that plug on other RV's for years with not problem.
Hurricaner
Hurricane Utah
Posted: 05/19/08 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Every once in a while someone gets away with using that recepacle for a TV because it is a short run to the power distribution box but in general it usally does not work. You can try it, if it does not blow the fuse, shutdown the inverter on low voltage or get too hot it will be fine but 90% percent of the time it doesn't work.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
sagexpman
Loveland, Colorado
Posted: 05/19/08 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the replies I really appreciate it. I think I will error on the side of caution and avoid that setup. What really frustrates me is my dealer said "sure no problem" a call to Jayco and advice from all of you probably saved me an expensive repair bill. Blasted dealer!
Thanks again, Rick
NHguy
NH
Posted: 05/19/08 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
If your inverter has the optional heavy wires for higher draws you might try to get at the main battery cables behind your converter.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, Battery Disconnect,
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
emaav
Hillsboro, Oregon
Posted: 05/19/08 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
On my 12vdc TV plug in the Jayco it states not to exceed 8 amps.
Me (Eli) 1972
DW (Monique) 1974
DS (Alex) 1996
DD (Amanda) 2002
1997 GMC Safari
2003 Jayco Kiwi 21C
