RV.Net Open Roads Forum: Technology Corner: cable reel?
 > cable reel?
hasheel
Durham,NC
Posted: 05/20/08 05:52am Link  |  Quote  |  Print  |  Notify Moderator
Any great ideas for satelitte cable, such as a reel for the cable.
Thanks in advance
2008 Tioga Ranger 31 W
02 Suzuki XL-7 toad
BrakeBuddy
dbates
Marion, Indiana
Posted: 05/20/08 06:22am Link  |  Quote  |  Print  |  Notify Moderator
These "CordPro" Click HERE should work OK for such a purpose.
Plus New Brunswick, Prince Edward Island & Nova Scotia
ShapeShifter
Buffalo, NY
Posted: 05/20/08 06:24am Link  |  Quote  |  Print  |  Notify Moderator
I was thinking of getting this: 25' Cable Reel
It's pricey, but seems like it would be convenient. It doesn't say what grade of cable it uses, although it does say it is compatible with portable satellite dishes. (But that doesn't necessarily mean it compatible with all satellite antennas.)
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
vonzoog
Delaware
Posted: 05/20/08 06:34am Link  |  Quote  |  Print  |  Notify Moderator
If it is RG6 cable then it will be fine. However, based upon my experience, 25 foot of cable is NOT enough.
If you have to ask why I drive a Diesel, then you will never understand.
2004 RAM 2500 SLT Quad Cab 4x4
Cummins(305/355) 48RE Auto 11.5 Rear
2004 Laredo 29GR
vonzoog
Delaware
Posted: 05/20/08 06:38am Link  |  Quote  |  Print  |  Notify Moderator
I have three of these sitting in my garage right now not in use. After three years of using them I said enough is enough. In actual use they are not as easy to use as you would think they would be. The one big negative is they collect dirt and water inside.
I spent good money for them and have not been that happy with them.
ShapeShifter
Buffalo, NY
Posted: 05/20/08 07:38am Link  |  Quote  |  Print  |  Notify Moderator
And that's the rub: it doesn't say what kind of cable it has. One can assume, but you know what happens then!
Probably true if you're looking for just the right place to put a portable dish. I'm looking at it for the occasion when a park has cable TV available, so I would only have to run to the pedestal. 25' should be more than enough for that.
Getting SOMETHING LIKE THIS would be able to hold more than enough cable for just about any situation. If it can hold 150 feet of extension cord, it might be able to hold something like 200 feet of RG6. And since you'd have to buy the cable separately, you'd know what quality of cable you're getting.
jauguston
Bellingham, WA
Posted: 05/20/08 08:55am Link  |  Quote  |  Print  |  Notify Moderator
I agree on 25' not being enough. I have 50' connected to my dish and carry another 50' extension. I find I have to get a fair distance away from the MH to get away from the compass being influenced by the metal in the coach.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
trafficmaker
SC
Posted: 05/20/08 09:13am Link  |  Quote  |  Print  |  Notify Moderator
I have 2 100' RG-6 cables taped together and this reel works just fine.
2005 F250 SD FX4 Crew Cab 6.0l PSD
2005 Gulfstream Sedona 31 FRBH
Wherever I happen to park
Posted: 05/20/08 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Cord pro is a very BAD choice for satellite cables The reason is that it puts a very tight bend in the middle of the cable, much tighter than recommended, this can change the cable's specs enough to make a big difference.
Suggestion is to look not to cable reels but garden hose reels. Go to Lowes or Home Depot and get a hose reel
This Reel Holds about 50 feet of twin-ax or 100 feet of single co-ax
joshjack
Alabama
Posted: 05/20/08 11:17am Link  |  Quote  |  Print  |  Notify Moderator
I would recommend that approach as well. Or even cheaper just buy a 50' or 100' reel of cable at Lowes and crimp both ends. Leave enough sticking through the center of the reel to connect and then unroll as much as you need.
J
03 Ram 1500 Quad Cab with Hemi 5.7, HD tow package, K&N Cold Air, B&W Companion + Ball, Prodigy,
1987 Prowler 27.5',
Macbook Pro 17" (Fastest Vista Laptop , iPhone)
Me and the DW and our
2 Dogs: Jackson (golden), Pumba (min-pin)
 > cable reel?
