Jetsfan68
NJ
Looking for some suggestions with a lot of wet grass....
My rig is located in the back yard on a pad- To get it on the road- I need to drive across the wet grass (you see where this is going...)
I don't want it to sink- any thoughts on things I can use like plywood? (or something else) to drive on to minimize damage?
lynndiwagon
Yukon, Oklahoma, USA
Not much you can do....I had the same problem. Finally bit the bullet and moved the 5ver to another location, poured cement, removed trees, and spent a lot of money. I can now back down the driveway, curve around onto the new drive and park next to the house on a cement pad. After filling ruts and getting the TV unstuck I finally saw the light. good luck..
Lynn & Diana Wagoner
One Shih Tszu
Two Boston Terriers
2005 Chevy 2500HD D/A
2006 HHII 29.5LKTG
Retired Gov't employee
shutdown
In The Dog House
IS IT EVER GOING TO STOP RAINING???? I am facing the same thing. we had a major remodel/addition put on this winter so my yard is already a mess from having the contractors in and out all winter. That being said i don't want to make worse than it already is.
I was going to put plywood down but I'd need 12 sheets, 4 for the truck+2 for the trailer PLUS another 6 to pull on to when i drive to the end of the first set.
I am just gonna bite the bullet and put it in 4low and go. I'll worry about the ruts later, i can fill in allot of ruts for what 12 sheets of plywood would cost.
1995brave
San Antonio, TX
Last year after i tried backing out of the backyard and sank the RV to it's axles in the mud(took three days of jacking it up and putting wood and concrete blocks down to level it and pull back into the yard). I used 2x10 and moved slowly, if they started to sink i would back up and put concrete blocks under the wood to spread out the load.
SpoiledRotten
Central Mississippi
The age old problem of not planning ahead. Just kidding a little with you. You already knew that could be a problem when you put it back there though. If I had a trip planned, it would be coming out anyway and the yard repair would just have to follow later. When you get it started rolling, just don't stop. Would hate to get a follow up post where you had to pay a big bill to get it unstuck in another part of the yard. Keep the momentum flowing. Good luck.
Just the 3 of us...SpoiledRotten, TotallyRotten, and ALittleRotten
2000 F-250 Lariat, CC
7.3 PSTD-Superchipped
2005 33RL2 New Vision - AKA "SpoiledRotten"
2000 Jeep Wrangler Sahara Edition
mockturtle
Northwest
You might reduce the tire pressure a bit, as this might increase traction.
Husband: Derek
Dog: Bucky
RV: 2000 Aerolite 19RB TT
TV: 1996 Chevrolet Blazer 6 cyl. 4WD
This car used to be our toad, now is our TV!
Cloud Dancer
San Antonio and Livingston TX USA
Remove the grass, crown the driveway and add side gutters for drainage. Bring in a few yards of #2 base material and spread it on the driveway, 1 to 2 inches thick.
All of my property is clay soil, and the above treatment has worked great,....no ruts, no bogs, no mud.
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
G & G Shelton
North Central Florida
I have been stuck almost once for every trip out with the 5'er. It has almost become expected. I have a spot of sugar sand right before I get to the grassy area where the trailer is currently parked. This time I used plywood. Worked well.
I agree with SpoiledRotten though. Just get rolling, and keep rolling until you are on solid ground.
2007 Raptor 3712TS Toy Hauler
2008 F-450 Lariat W/ Lots-o-Options (Became mine on 2/22/2007)
jay2003
San Joaquin Valley, California
Plywood may snap under the weight of the rig. Do you have a stack of the lynx levelers? Make you're own ramp. Yes they may sink but only to a point and you'll have more of a solid surface to drive on.
Others have suggested drainage, cement, etc... there is a company out there though that makes what's called "Drive On Grass". I need to find the link though. I saw the company at a home/garden show out here. They basically install something very similar to Lynx levelers where the grass can grow through them so the yard doesn't look as "ugly". Very driveable and they actually advertise for RV use.
05 Toyota Tacoma DC 4x4 SB Off-Road Package w/Tow 128" WB
2005 KZ Jag 24JB*Newer Model Floorplans Slightly Different
Prodigy Brake, WD hitch, friction sway
Garmin GPSMAP 60CSx
Honda EU2000i Generator
Me.. the wife, the 5 year old, and the 2 year old
Camping Dutchman
NJ
5/8 sheets of board ripped in half, lay them out and make a run for it. I take my 33,000 lb truck over plywood to keep from damaging lawns and only had a sinkage problem once in the last 12 years. I buy the cheap plywood, I don't recall the proper name, usually costs me around 4.50 a sheet, then I have them rip it... I have used the same sheets for three years. not sure how long a run you have, also where in NJ, I would lend you my boards if you were up north
2008 Chevy 3500 cc DRW Duramax
2009 Cedar Creek Silverback
2004 United Specialties Sold
Member:Good Sam Club Haulin Highlanders
