dmzempr
ohio
Just wondered what some of the tried and true remedies of reducing camper bounce are once we are all set up? Its not bad, but for me though I notice a lot of that stuff so its a little annoying.
solutions?
2004 Yukon XL 5.3, 3.73, Prodigy, Equalizer 1k/10k
2007 Jayco 29A
5 campers + dog
b_salgado
Salisbury ,NC,USA
Especially with longer units, the frame will flex a bit, or the suspension movement, will allow you to feel movement in the trailer. I found that a good set of between the wheel chocks helps tremendously. Some others have installed another set of stab jacks near the axles. This seems to help out a bit also. Some others have the portable jacks that they place near the axles and remove later.
04 Lariat Supercrew 4x4,5.4,3.73, Edge tuner, flowmaster duals
06 Trail Bay 31BH, nicely optioned
Equal-i-zer
Prodigy
Follow vehicle, 05 KIA Sorento EX for the golden retrievers.
goodcruisin
Greenwood, IN
I was annoyed by the movement too. I did some online research and went into a guys TT who installed the following equipment which eliminated almost all movement. I was impressed at the reduction of movement over a standard scissor jack. He used BAL Stabilizers and these wheel chocks. The BALs did a great job and reducing side to side movement and the wheel chocks eliminated the front to back movement. I was going to install these same things on my TT but ended up moving into a MH.
John (USN Ret) and Debbie
The Paw Pack (Freckles, Stinky & Ranger)
'96 Monaco Windsor 36' DP 8.3L Cummins
Ready Brake w/ Demco Excali-bar
'03 Ford Explorer (Toad)
'04 Honda Insight
'04 Volvo S80 AWD
'74 Dart Swinger Drag Car
14' Boat 9.9 Mercury
pulsar
Lewisville, NC
Moved from Forum Technical Support.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
martinar
Cincinnati, OH
If its just a weekend trip, I keep it hitched, lower the tongue and set up the stabilizers. Takes care of it. Longer trips, I use the Bal chocks and the stabilizer jacks to add support at the 4 corners
fncampn
Gardnerville, NV
I just bought a set of these:
BAL Lock Stablizers
I haven't installed them yet but I suspect they will help considerably. I did notice one of my stab jacks had a cracked weld where it attaches to the frame. I'm sure that it is contributing to the TT movement as well. Just something to check...
Cold Weather Camping Mods
A Bunch of Ways to Mod Your RV
'08 Ford F150KR Screw 5.4L LB Auto 3.73LS 4x4
'07 Ford F350 XLT CC LB PSD Auto 3.73 4x4 - SOLD
'08 Thor Summit 27RBS TT - 9000 GVWR, 7500 loaded, 875 TW
'06 Kipor 3500Ti Generator
JaySki
Metro Detroit
Search the subject on the forums here and you'll find a ton of answers to your issue.
seatboard
South Carolina
Our's does the same thing but I think it's because it is a ....BOUNDER.
revetch
Stockton, CA
Rotochoks and Bal Lock-Arm stabilizers. No more bounce at all. Great products
Revetch
scout3399
raleigh nc
try this lowwer the stabilizers that it almost on the ground and move it back a forth not real stabil the farer it extended the worst it get the bal locking arm do a great job
