seabeecamper
Green Cove Springs, Fl
I have a Troy built 5500w generator I started it up the other day and checked the voltage at the outlet. It read 130v. Question is if I hook the generator up to my tt will the 10 extra volts damage anything? I also do not see any sort of idle to bring the rpms down to lower the voltage output. I am thinking as soon as I put a load to it it should reduce the rpms thus reducing output viltage. Am I right?
2008 Hornet Hideout 19FLH "The Beehive"
2004 Dodge 2500 Crew Cab
U.S.N Seabee "Can Do"
NMCB-1
NMCB-7
NMCB-14
Tenn Stud
Northeast, TN
I doubt that 130vac will harm anything. As soon as you load it should reduce the voltage some. I would turn everything off first, If you have a portable electric heater test it using the heater before hooking it to your trailer read the voltage
youth4him
Belgrade, MT
Check it under load, it should stabilize a bit. The electric heater is a good idea.
I found this link to some converter sales, and it shows a voltage tolerance of up to 130VAC.
http://www.progressivedyn.com/power_converters.html
KD
Trip of a Lifetime Blog - 10372 Miles, 88 Days, 4 Humans, 1 Mini Daschund...FUN!
Wildwood LE 23BH
2003 Chevy Suburban 4x4 Z71 5.3L 3.73
tvman44
Southwest Louisiana
When you load it, it will drop a little.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
fncampn
Gardnerville, NV
I had a Craftsman 4000EX a while back and it measured 129 VAC under no load. Running a 13,500 BTU A/C the voltage measured 121 VAC. As long as the voltage doesn't fluctuate too much, it should be OK.
As for the RPMs, I believe your type of generator must run at a constant 3600 RMPs in order to provide 60 Hz frequency required for AC appliances. So the RPMs shouldn't be dropping at all. If the RPMs are higher than 3600, the max RPM meeds to be adjusted by a qualified generator tech.
If after doing the heater test suggested above and the voltage drops some, I would get a simple analog volt meter that you can plug in to a receptacle in the RV and monitor the voltage under various loads.
Cold Weather Camping Mods
A Bunch of Ways to Mod Your RV
'08 Ford F150KR Screw 5.4L LB Auto 3.73LS 4x4
'07 Ford F350 XLT CC LB PSD Auto 3.73 4x4 - SOLD
'08 Thor Summit 27RBS TT - 9000 GVWR, 7500 loaded, 875 TW
'06 Kipor 3500Ti Generator
MNtundraRet
Bloomington, MN
You may be waking up the dead by using that generator in a campground. The generator would most likely work, but it may not have an approved spark arrestor, for use in most state, and Federal campgrounds, and may not be allowed if to noisy.
Mark
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
seabeecamper
thank you for all of the replies. I do not plan on using in campground I mainly have the genny for hurricane purposes, races or boondocking.
Gdetrailer
PA
seabeecamper, you are brave for posting about a genny that doesn't cost $1,000 on here. Most likely posting should have been in Tech issues for better response.
130V no load should be fine, voltage will drop some under load (unlike utility voltage which most cases won't drop much if at all) so should cause no harm.
