lavocat
Eunice, Louisiana
My pull down window awning strap broke off. Torn actually. Can it be replaced and where do I get one. I have a 2004 Monaco Camelot.
2004 Monaco Camelot
2006 GMC Envoy Denali 4x4
Blue Ox Adventa II
SMI SIlent Partner
Sully2
Cincinnati
lavocat wrote: My pull down window awning strap broke off. Torn actually. Can it be replaced and where do I get one. I have a 2004 Monaco Camelot.
They do it all the time. "Sun rot"...being out in the sun can destroy fabrics.
The end of the strap had a short length of rubber "dowel" sewn into it....slide it out of the track thats in the awning tube..take it to the RV shop to get the same identical diameter and re-install.
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
hgernhardtjr
Parkersburg, WV USA
Most any RV dealer with a parts division will have them. Even Camping World ... they sell them for under $5. Or make your own from strap material and a small piece of dowel rod or rubber that will slide into the slot. In fact, I think you get 2 for about 3.99 (at least the last time I got them a year or so ago if I remember correctly)
SAR Tracker
Sandy Eggo, Calif
Camping World Ad
Rusty & Cheryl & Serendipity (dog & Chief Security Officer)
2000 F150 4x4 5.4L/3.55 (108k miles and goin' STRONG!)
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
dons2346
Sioux Falls, SD, formerly of So. CA
I would start with the awning manufacturer. They might even give you a free one.
SS Slacker
Lino Lakes, MN
You can also order the original replacement strap (carefree or A&E) directly from Monaco's on-line store. I did that and they were a perfect fit. Got a new one for the main awning as long as I was already ordering and keep the old one for a spare.
Dan & Tracy
2 kids ages 4 and 6
2003 HR Neptune 36PBD
300 ISB Cummins/5-Speed
Periscope Man
Chesapeake, VA. USA
lavocat, To replace the awning strap you have to slide the rubber dowel from the slot it’s in. This can be a pain because most of the time there is not enough room between the roller tube and the end cap. If you remove the end cap, you have to be careful that the spring does not unwind too fast. I have found that if you get a drill bit slightly larger than the rubber dowel and you drill a hole near the end of the at a 45 degree angle into the slot the strap is in, you can slide the rubber over and using a small screw driver get the rubber to enter the hole you just drilled it will come right out. The new strap will go back in the same way. Have done this a number of times ands it works. With the hole drilled off to the side, the strap cannot come out one its own, because the tension keeps it centered.
Earl D
Retired Submariner
2003 Country Coach Intrigue
Toad 2001 Honda Odyssey
SS Slacker
Lino Lakes, MN
Periscope Man wrote: lavocat, To replace the awning strap you have to slide the rubber dowel from the slot it’s in. This can be a pain because most of the time there is not enough room between the roller tube and the end cap. If you remove the end cap, you have to be careful that the spring does not unwind too fast. I have found that if you get a drill bit slightly larger than the rubber dowel and you drill a hole near the end of the at a 45 degree angle into the slot the strap is in, you can slide the rubber over and using a small screw driver get the rubber to enter the hole you just drilled it will come right out. The new strap will go back in the same way. Have done this a number of times ands it works. With the hole drilled off to the side, the strap cannot come out one its own, because the tension keeps it centered.
This is great advice. This is exactly how I replaced mine and it worked perfectly.
Sully2
Cincinnati
Never mind!..????...But I have NEVER had to remove the end cap and use a drill to get the end of the strap out of the groove in the awning tube????
lavocat
Eunice, Louisiana
well I have the new strap but there is no gap between the tube and the end cap. Also, ig one were to drill a hole at a 45 at the end, how would one keep the thing unrolled while doing so???
