RV.Net Open Roads Forum: Towing: Anyone try this with their dual cam sway?
Search only in Towing
Open Roads Forum  >  Towing
 > Anyone try this with their dual cam sway?
theextricator
Newton NJ
Posted: 05/21/08 11:46am Link  |  Quote  |  Print  |  Notify Moderator
I just upgraded last fall to a Fleetwood Hornet trailer. The overall length for the new trailer is 31 1/2'. I had the dealer install my friction sway on the trailer and decided after two trips last fall that I was going to upgrade to the Reese dual cam hp setup this spring. I installed the new reese setup and am very happy with it. My question is that is there any reason that I couldn't also use the friction sway??? The brackets are still there and it does not interfere with anything. My thinking is that on the open road it would be just a little more security against the tractor trailers passing at hight rates of speed.
NHguy
NH
Posted: 05/21/08 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
I found that the DC was so good it wouldn't have been necessary. I suppose you could try it with both. My thinking,...too much stuff to hook up, don't bother.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, Battery Disconnect,
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
ozman
Ma.
Posted: 05/21/08 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
I used the hp for a few years,very happy.I dont think its a good idea using friction bars.I think it would work against the cams.I am not an expert.
dodge guy
Chicago, western subs.
Posted: 05/21/08 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
I believe the friction bar will work against the DC. it would slow down the return to center feature the DC has!
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
rolnrolnroln
WA
Posted: 05/21/08 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
Friction sway controls work by adding resistance to horizontal movement in the hitch connection. The DC uses a dynamic action. By using both you are slowing down and impeding the action of the DC. Kinda like pouring molasses into a watch. Like the other posters say, don't do it. If the DC isn't enough by itself, something else is amiss.
rhondavid
Birmingham, Al
Posted: 05/21/08 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Donk't bother with using the friction controller. I did that for a while. Forgot to put the friction controller on one time and found the TT towed much better without the friction controller. I believe the DC and friction controller were working against each other. I use the DC solely now and very pleased with the performance. Friction controller is just paying around collecting dust at this point.
David,Wife,4 kids,SIL,1 grandchild
2003 Ford Excursion Eddie Bauer 7.3 PSD w/3.73 rear end
Jayco Kiwi Too 30T bunkhouse w/triple bunks
Prodigy Controller
Reese Dual Cam HP
Michelin LTX M/S
Topsail Hill Cult Member
Bessie-Hunter
Lyons, OH, USA
Posted: 05/21/08 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
I use my friction sway with my DC in high cross winds conditions. I find it provides better stability in these conditions. I have use it with the DC even in calm conditions and have found no adverse effects. So, try it, you may like it or not, you decide. It will not hurt the way DC works, because the DC is still going to try to straighten the trailer up with the TV.
Dave & Ellen, Don and Ross
'04 Dodge Durango 5.7 "Ya, it's got a Hemi" 3:55
Reese Dual-Cam WD
Jordan Ultima 2020
'05 Surveyor SV255RS
skipnchar
Topeka Kansas USA
Posted: 05/21/08 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Seems like a waste of time to me but probably won't harm anything. Might be better to spend a little time fine tuning the DC system and you shouldn't even notice passing trucks.
Jim C
Fl Space Coast
Posted: 05/22/08 05:51am Link  |  Quote  |  Print  |  Notify Moderator
I did that when I got my D/C then on one trip I forgot it Seemed to me like it was much better without the friction bar. Try both ways and see what you think...
Jim C. & Joyce 03 Mallard lite 25J
Chevy 1500, 350,3.73 gears
Rease duel cam, C.I.P.A. mirrors, Prodigy brakes.
Cooper LT'S Monroe coil over shocks Direct TV
Together 53 years
Member No frills good sam's club
Road Ruler
Canada
Posted: 05/22/08 06:19am Link  |  Quote  |  Print  |  Notify Moderator
We are using a pro set up combination (Can Am). We use the reese DC and they did not recommend adding any extra sway control. In ten years of towing we have not had a single sway issue.
