RV.Net Open Roads Forum: Travel Trailers: Leave slide out while away??
 > Leave slide out while away??
Fraser in YYZ
East York, Canada
Posted: 05/21/08 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all. We are thinking of renting a seasonal site to "store" our trailer while not traveling (ends up being only a little more $ to do so and have a spot for the winter as well) So here's the question. Can or should we leave the rear slide (Queen bed) out when we are not there? Not a big deal to close but just wondering if it would be ok if left out.
Thanks in advance......
Fraser
DW
2 sons 13+16
2008 Jayco 213 Exp
2005 Dodge Durango 5.7 Hemi Magnum
Factory tow package
Prodigy brake controller
Husky WD hitch with friction anti-sway
McKesh tow mirrors
A bad day of camping is better than ANY day stuck in the city!!
JFG
TN
Posted: 05/21/08 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
If it has a topper, I would bring in.
Fred
stevent
Marysville, Michigan
Posted: 05/21/08 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
We leave our slides out without any issues.
Stevent
JJBIRISH
Butler, PA, USA
Posted: 05/21/08 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
I think if you check with the dealer and mfg, they would recommend brining it in... not that being out hurts it but it should be exercised like most mechanical things should... it also helps keep the seals from sticking to the sides and tearing loose...
so if you want to know if you have to... no
if you are asking should you... my opinion is bring it in...
I also think it's a good idea if its closed for long periods it should be moved out as a part of a maintenance item...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
cmartin7143
ILL
Posted: 05/21/08 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
we leave ours out all summer,in for winter. We do run them in and out every few weeks (6-8) just to exersise them. Check the tops prior and look for debris. we never use supports under the slides too much chance of problems and dealer said NO.
o
fncampn
Gardnerville, NV
Posted: 05/21/08 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
I would bring it in as well. Even if it has a topper, it can be damaged by excessive wind, water, and falling debris. Over time, tree sap can also become an issue and can be difficult to remove. If the slide is easy to bring in, it might give you some peace of mind knowing you won't have any issues while you are away.
Cold Weather Camping Mods
A Bunch of Ways to Mod Your RV
'08 Ford F150KR Screw 5.4L LB Auto 3.73LS 4x4
'07 Ford F350 XLT CC LB PSD Auto 3.73 4x4 - SOLD
'08 Thor Summit 27RBS TT - 9000 GVWR, 7500 loaded, 875 TW
'06 Kipor 3500Ti Generator
skipnchar
Topeka Kansas USA
Posted: 05/21/08 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
Ultraviolet rays can do a lot of damage on tent ends on a HTT if left exposed unnecessarily. I'd close er up.
djenson
Thompson ND
Posted: 05/21/08 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
We have had a trailer (with double slides) on a seasonal site for the past 10 years and have left the slides out all season for all ten years. This year we opened in April and then got snow on it. No problems. I do inspect the slides and roof a couple of times each season. Do what makes you feel comfortable and causes you the least amount of stress.
Retirement: Waking up with nothing to do and going to bed with half of it done.
Hornet28BHDS
Parker, PA
Posted: 05/21/08 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
How long will you usually be away from the TT?
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
DocP
Brunswick, Ohio
Posted: 05/22/08 04:10am Link  |  Quote  |  Print  |  Notify Moderator
We also have a seasonal site (and pull in and out throughout the year). While we are at the seasonal site I always bring the slide in. I don't have a topper, so before bringing the slide in, I always do a quick climb up on my ladder to make sure that there is no debris (e.g., tree limbs, leaves, etc.).
By the way, we're in the same position ... since we have to pay for storage, the seasonal site (with full hookups) doesn't end up costing that much more than the outside storage sites around us are getting.
2008 Keystone Freedom Lite 281RL
1998 Breckenridge Park Model
2004 Chevy Avalanche, 5.3L, 3.73:1, 4X4,
Auxiliary transmission oil cooler,
Z71 off-road towing package
Reese Trunnion WD, Dual Cam, Prodigy
Yamaha EF2400IS generator
