mostek
Little Chute, WI
Well we just got back from our first time out with the TT. It went very well and we didn't have to run to the store once. Mainly because of all of the advice we got from this site. We did come up with a list of about 20 things to take along next time and about 7 things that need to be fixed or tweaked.
As I was putting things away I came to the water hoses. What does everybody do with them. Do you drain them, hang them, fill them or what? I don't want it to get all gross inside. Any advice would be greatly appreciated.
Thanks Alot,
Nick
swebber
Brunswick , MD
I drain mine and then connect both ends together to keep anything from getting inside.
Some posters have put washers with screens over the end and hold it in there by drilling out the centers of hose caps.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
tvman44
Southwest Louisiana
I drain my water hose and then coil it up and connect the ends together to keep anything from getting inside the hose then store it in the basement.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
MudChucker
Winnipeg Manitoba
I drain mine at the site as best i can, and stow away... when i get to the next site I flush a little water through it before I hook it back up to the TT a couple times a season when we give the TT a big clean I submerge the entire hose in a clean 5 gallon bucket filled with decent bleach and water solution...I have been told Im excessive with this sort of stuff but I like to tinker...
2006 Springdale 292BHLS
2007 GMC Sierra 2500HD SLT 6.0
KC0BID
Denver, CO
tvman44 wrote: I drain my water hose and then coil it up and connect the ends together to keep anything from getting inside the hose then store it in the basement.
ditto! I also store it as far away from my stinky slinky and flash kit hose as possible.
Crossroads Sunset Trail 30BH
Dodge Ram 1500 TV with dual exhaust and K&N cool air intake
2003 Polaris 600 Twin ATV
2006 SunL 110 ATV
1979 Honda Goldwing (riding restore)
PattieAM
Maryland
I drain mine, coil and connect the ends and stow in a giant zip lock bag with the water filter and pressure regulator (and additional washers)and a crescent wrench! About 2 years ago I did take my hose inside and submerge it in a bathtub of bleach water to clean both inside the hose and outside - all pretty again!
MudChucker
Winnipeg Manitoba
I dont connect both ends together so that the hose can breath... I'd prefer it dry out then grow fungus inside...as far as anything getting inside, thats why i flush a little through before I hook up...
PopBeavers
San Jose, CA
I flush with chlorinated city water, drain as best I can then coil can connect the ends together. Mostly I only use them at home with city water. I only use them in a campground if we stay more than 4 days. This is when I flush them when I get home.
When I sanitize the fresh water tanks each spring, I run the chlorine through all of the hoses on the way to the tank. This gets a burst of strong chlorine solution in the hoses once a year.
Wayne in San Jose
TV1:2002 Chevy 1500HD 4wd Crew Cab,Valley Odyssey brake ctlr,McKesh mirrors
TV2:2008 GMC 2500HD long bed 4wd Crew Cab,GMC brake ctlr,GMC mirrors
TT:Trailmanor 2720
Honda 2000
Yamaha WR250R,Polaris Sportsman 700 X2,Polaris Scrambler 500
rockhillmanor
On the Road
MudChucker wrote: I dont connect both ends together so that the hose can breath... I'd prefer it dry out then grow fungus inside...as far as anything getting inside, thats why i flush a little through before I hook up...
I used to hook the ends together too until someone here mentioned the growth that goes on in there.
So now I just screw a regulator on each of the ends of the hose, the regulator has a screen on it. Hose can breath and nothing can crawl in. The regulator trick is also good to use when you have to break camp for propane or whatever, take off your hose from MH and screw on the regulator.
I do it when I have time run a weak bleach and water solution thru it before hook up, my bays are certainly not germ free.
31 ft Four Winds
Chevy Tracker 4x4 Blue Ox
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
Lissa
California
i've also read to connect the hoses together but was also wondering about fungus going in them - i only noticed one person who also mentioned this - i'm thinking it would be best to let the hoses dry out first then screw the ends together.
Also wondering - i just took my first rv trip so used my hoses and water filter for the first time - and i noticed the water tasted terrible at the rv park i stayed (their water is chlorinated) i intended to taste the water elsewhere in the park to see if it was the same but forgot - was wondering if the awful taste could be from the new hoses and or new water filter? or did this area just have yucky tasting water?
