RV.Net Open Roads Forum: Hybrid Travel Trailers: Using Cruise Control while towing
Open Roads Forum  >  Hybrid Travel Trailers
 > Using Cruise Control while towing
dfoxhoven
Elizabethtown, Pa
Posted: 05/21/08 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
I'm just curious, does anyone use cruise control while towing their HTT? Obviously if you're in some serious mountains, it probably wouldn't make sense, but what about the highway? I turn on Haul Mode in my truck, and find myself trying to keep it between 55-60mph, but my foot gets tired after a while from trying to keep it there. Just wondering if there are any effects or if it shouldn't be done?
Thanks,
http://good-times.webshots.com/photo/2650276690103632465PYYFzx
'09 KZ Spree 324bhs
2007 Toyota Tundra 5.7 V8
Daryl
Mary
Kaisen
Echo (Dog)
ccand4kids
Berks County, PA
Posted: 05/21/08 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
I tow in cruise on the highway in tow/haul mode, I too like to keep it between 55-60 mph, I don't feel comfortable going over 60 even though the 'Burb can do it.I don't do it in the rain, I like to be able to slow down on wet roads by just taking my foot off the gas.
Cindy
DH,2DS,2DD
2008 Suburban 1500 Active Fuel Management
2006 Coyote 23CS
mrjimboalaska
Abilene, Tx. at the moment
Posted: 05/21/08 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
I use cruise all the time when pulling the TT, and only use tow/haul on heavy grades. Why do people use the tow/haul all the time? I just see the RPM's go up......I pull at 60-62 mph....
Jayco-noslide
Galesburg,Il., USA
Posted: 05/21/08 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I use cruise and tow/haul mode which prevents the trans from ever shifting into overdrive. But, when I approach an upgrade, I tap the break pedal to turn off the cruise to prevent such high-speed downshifts into 2nd gear. Then, hit resume when I'm back on the level. I don't think I could drive long distance any more without cruise.
Jayco-noslide
kaydeejay
SE Michigan, USA
Posted: 05/21/08 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
Cruise - anywhere the traffic does not get in the way!
Tow/Haul ALWAYS as it keeps the trans temps down and also enables downshift engine braking (at least on my D'max).
Keith J, Retired from GM Engineering
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA.
1999 Sunnybrook 27RKFS Fiver
Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors.
jefff929
Pacific wonderland, wet side
Posted: 05/21/08 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
*** Why do people use the tow/haul all the time? I just see the RPM's go up......I pull at 60-62 mph....
to cool the trany.
2001 Dodge 2500 QC, Diesel, Auto, 4x4 Shortbox, Stull running boards, 24.5' Prowler 5er
Diesel Bombers My Baby
Another NWBomber
Dick_B
Palos Heights, IL USA
Posted: 05/21/08 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
What does the Owners Manual state? We use cruise control all the time except in the mountains and only use Tow Haul in towns.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Kenneth
Washington, the state
No problem with cruise control unless it causes frequent up & down shifts.
Experiment with tow/haul mode to see which works most smoothly on your truck and your trailer in the terrain you're in today.
campingforsix
Exton, Pa.
Posted: 05/21/08 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
i use tow/haul mode all the time and it goes into OD. the only thing i notice are the shift points are different. as for criuse control, i use it when traffic makes sense and not on steep grades. i guess you will get different answers depending on everyones make and model year. good luck
sharker6
Shelbyville, Kentucky
Posted: 05/21/08 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
My Nissan owner's manual says do not use cruise control. What does yours say.
2005 Xterra off road 4X4, 2007 26' Aluma-Lite, WD w/ friction sway, Prodigy, Yamaha EF2400, 400w inverter, front carrier w/ rod holders, Dish Network
