trnfla
Tampa
Yes
Have a great time camping,
Terry
Please say a Prayer for my 12 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
mrjimboalaska
Abilene, Tx. at the moment
jefff929 wrote: mrjimboalaska wrote: *** Why do people use the tow/haul all the time? I just see the RPM's go up......I pull at 60-62 mph.... to cool the trany.
I've never had my Allison Tranny overheat. My 02 Duramax has 60K miles on it now, about 80% of those miles with 11,000 pounds or more behind it, with my Sportsman 500 in the bed.
Yes, my mileage is low, I let my FIL drive it for 2 years while we were out of country.
Have you heard of people having temp problems?
Do you still feel that you are not losing any fuel economy?
I may try this on our trip to Idaho in 2 weeks and see. I've always just used it for grades in the past.
eddie3260
Florence, al
When not running in the mountains, I tow in overdrive and use the cruise. I have used the tow mode but my tranny runs 15-20 degrees cooler in overdrive. I live in North Alabama so we don't have many long steep inclines.
skipnchar
Topeka Kansas USA
I've twoed 70,000 miles with my Ford and probably 75% of that has been with the cruise on. Can't even imagine why anyone would NOT use it unless there were ice or snow involved. Why would the manufacturer put a CC in the truck then tell you not to use it?
emaav
Hillsboro, Oregon
Cruise is used for nice flat roads/highways, set it about 60.
Me (Eli) 1972
DW (Monique) 1974
DS (Alex) 1996
DD (Amanda) 2002
1997 GMC Safari
2003 Jayco Kiwi 21C
Chuck_S
Broadview Hts, OH, USA
We routinely run across the PA Turnpike with the Roo 23SS behind my Expedition. Transmission is in Drive with overdrive selected -- or I'd not get 5th and 6th gears -- and cruise is set for about 65 mph which is 1800 rpm. I kick the cruise off only on a couple of very steep grades to avoid the transmission making a violent downshift.
I've been monitoring transmission and coolant temperatures and OD is fine. But I'm running about 4000 pounds less trailer than my maximum towing capacity and the truck has larger engine and transmission radiators as part of the HD tow package.
Fit a transmission temperature gage if you have doubts.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
odielovestocamp
Muskoka, Canada
Chuck_S wrote: We routinely run across the PA Turnpike with the Roo 23SS behind my Expedition. Transmission is in Drive with overdrive selected -- or I'd not get 5th and 6th gears -- and cruise is set for about 65 mph which is 1800 rpm. I kick the cruise off only on a couple of very steep grades to avoid the transmission making a violent downshift.
-- Chuck
Thanks Chuck, I was waiting to see if you would reply. I just love your wisdom and your ideas and trust what you have to say. Not that I don't other people, but I feel relief when I see that you have responded to post such as this one. Thanks again for your imput!!!
Happy Camping Everyone!!!!
2007 Terry Dakota Hybrid
Honda Odessey but looking to upgrade next summer to a Ridgeline.
Wayne (aka Hackett) and Wendy
and 3 kids that have left the nest!!!
Drippin
Dripping Springs, TX
We use cruise as much as possible. When we had the HTT I only used tow/haul when we were in hilly areas. However now with a heavier trailer, about 2X the weight of the HTT, I use tow/haul all of the time. It will hold a gear longer which kepts the trans from shifting up and down so much. This will should reduce wear and help it last longer.
A man, his wife, a son and Cody the Goldendoodle.
2008 Laredo 284BHS, 2001 Chevy Sliverado 2500HD 4X4 4.10, Equal-i-zer, Primus, Subaru RG4300iS
cp1971
Martinsville, IN
Using cruise does not affect towing. The cruise just simulates your foot on the pedal. I use tow/haul all the time which in my 03 Dodge just shuts of overdrive and makes it hold gears a little longer.
bandt
Cambridge, Ontario Canada
I experimented a little this weekend. I used cruise as long as the road permits. I have always heard that tow/haul locks out your overdrive which would keep the truck in a higher rpm range, meaning more fuel consumption. Tried tow/haul for the first time this weekend and low and behold overdrive gears are not locked and the truck ran 2 to 3 L/100 kms better. I was surprised and will be using the tow mode from now on.
2008 Rockwood Roo 21SS
2007 Toyota Tundra Crew Max 5.7 Liter
