chipster
Lasalle, Ontario, Canada
I have had the prodigy now for four years and my question is If I get it so it feels like it is braking well at highway speeds or even 25+_MPH. The problem arises when I get to campground or into gas station or what have you, it grabs way to hard. The only way I can get it to work is I have to constantly hit the boost button down to 0 or is B.1. Then when back out on road I have to set it back up to B.3.
Brian/Lynette and the 3 Cubs,
Brand new KZ 2008 Sportsmen Sportster 26P
2004 F250 CC 6.0LFX4. Husky Hitch, Reese Dual Cam Sway Torsion Bars, Prodigy Brake Controller
Old Rig
b_salgado
Salisbury ,NC,USA
It sounds like you don't have your voltage high enough. I run constantly on B1. I rarely need to touch it. I don't recall what the voltage is set at now. I am hooking up friday morning and I can check it for you then if you would like. My first guess would be voltage. My second guess is that your brakes on your TT may need to be adjusted.
04 Lariat Supercrew 4x4,5.4,3.73, Edge tuner, flowmaster duals
06 Trail Bay 31BH, nicely optioned
Equal-i-zer
Prodigy
Follow vehicle, 05 KIA Sorento EX for the golden retrievers.
chipster
I have found I usually set it at 9 volts. Trailer is brand new but I guess that does not mean brakes do not need adjusting. Just read another post where they set it at 12 volts. maybe I will give that a try and leave it at B1 as it is a toy hauler and rather heavy.
kaydeejay
SE Michigan, USA
chipster wrote: I have found I usually set it at 9 volts. Trailer is brand new but I guess that does not mean brakes do not need adjusting. Just read another post where they set it at 12 volts. maybe I will give that a try and leave it at B1 as it is a toy hauler and rather heavy. How do you know how many volts you are applying - I thought the Prodigy indicated current (amps)?
Keith J, Retired from GM Engineering
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA.
1999 Sunnybrook 27RKFS Fiver
Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors.
chipster
Nope it is voltage
quote from Tekonsha web site
"Digital display depicts voltage delivery to trailer during braking. "
emaav
Hillsboro, Oregon
The P3 show's amps and voltage.
Me (Eli) 1972
DW (Monique) 1974
DS (Alex) 1996
DD (Amanda) 2002
1997 GMC Safari
2003 Jayco Kiwi 21C
Chuck&Gail
In the Colorado Mountains
IMO try setting it per manual. That worked great for me.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
JeeperAz
Az
Mine does the same. I thought it was normal. I never mess with boost though.
'06 GMC 2500HD Duramax(LBZ)
'06 Ragen FB2500
Larry & Mindy
Backseat: Maya (black lab)
chipster
Chuck&Gail wrote: IMO try setting it per manual. That worked great for me.
I have used this on 3 trailers now and not one will function as per set up instructions. Nor have I seen anyone be able to lock up there tires on dry pavement.
I am beginning to think it is just what each individual feels is proper braking power. Just like some people think their F150 tows that 8000# trailer just fine and gets great MPG.
Bubtoofat
Westland, Michigan
I just packed the bearings and adjusted the brakes this past weekend. I tried setting the Prodigy per the instructions and could never get the wheels to lock up. It stops OK @ B1 and 10 volts. But at highway speeds I think I'll set the boost to B3. I could get the brakes to lock with my old Reese controller but the Prodigy seems to stop the trailer better, if that makes any sense. I think I need to upgrade my wiring on the TT.
