RV.Net Open Roads Forum: Tech Issues: Blown City Water Inlet
 > Blown City Water Inlet
Sixpack Jesus
Canadian, eh.
Posted: 05/21/08 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
Greetings,
I have recently filled my trailer with water and was hoping to flush out the lines as normal only to find water gushing out the city water inlet when the pump is on. I did a search but did not find any details on how to swap the inlet out. Is it as simple as unscrewing the three screws that surround it and finding the replacement to rescrew back in?
Does anybody have a step by step procedure? Pictures would be helpful.
Thanks.
2006 27 Foot Komfort Trailblazer 5th Wheel
375 Watts Solar
Solar Boost 2000 Charge Controller
4 Trojan Group 24s in parallel
Honda EU2000i generator
1500 Watt Sine Wave GoPower Inverter
Serena
US
Posted: 05/21/08 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
If yours is like mine, it really does just screw on. So simple, I don't think there were even any instructions in the box.
Serena
I Know Where I Been, Cuz I Was There When I Went.
96Bounder30E
Birthplace of the Boysenberry, Orange County, CA
Posted: 05/21/08 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
I've swapped mine out a couple of times now on my 12 year old RV......the last time it started leaking I decided to fix it permanently.......I went to Home Depot and picked up a garden hose valve.........and screwed it on and shut the leak off for good........you might consider giving it a try?
javaseuf
Southern Cal
Posted: 05/21/08 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
Many times you can repair this issue by just cleaning out the check valve behind the hose fitting.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
sagexpman
Loveland, Colorado
Posted: 05/21/08 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
yes it is really easy. Remove the thee screws on the outer ring that holds it to the TT exterior. Then you will be able to pull it out a bit so that you can unscrew it from the plumbing.
Rick
1998 HD Chevy Silverado 2500
- Super Charged Vortec 5.7
- Air Lift Suspension System
- Drawtite WD hitch with 1200# bars
- Drawtite DC sway control
- Honda EU3000IS
2005 Jayco JayFlight 31BHS
Chuck&Gail
In the Colorado Mountains
Posted: 05/21/08 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
I use a hose shutoff as suggested above. Worked fine for years now.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
Bumpyroad
Virginia
Posted: 05/22/08 05:06am Link  |  Quote  |  Print  |  Notify Moderator
I was going to point out that Lowes has a larger type of valve which I think is what is pictured, not that tiny standard one.
bumpy
Wherever I happen to park
Posted: 05/22/08 08:32am Link  |  Quote  |  Print  |  Notify Moderator
A common problem..
First inspect the screen on the inlet, is it well formed or has it been "Pressed in" if the latter remove it, re-form it and check again
If it's well formed remove it anyway.. Just behind the screen is a plastic pin,
NOTE YOU WILL GET WET, WEAR RAIN GEAR
WIth the water pump on press in on this pin, water flow should INCREASE, You may also flush out a bit of "Something" (I have no clue as to what since it don't belong there) release the pin and hopefully water flow will stop
If not, replace the inlet
startcamping
Rockford, IL
Posted: 05/27/08 10:03am Link  |  Quote  |  Print  |  Notify Moderator
I need to replace the city water inlet on my travel trailer. I forgot to winterize the city water connection and there is now a leak in it. It is a surface mount model and I removed the three screws around it. This loosens it, but how do I actually remove it and replace the new one? How is the inlet connected to the pipes inside the camper? The photo below is the new part that I need to replace it with. Thanks! Any advice would be appreciated.
JSGlow
Carol Stream, IL
Posted: 06/02/08 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Just replaced mine. Here's how.
Remove the three screws that attach the fitting to the side of the trailer.
Go inside the trailer and find where the connection comes into the trailer. In my case, its in a cabinet. Hopefully, your's is similarly located.
Disconnect the plastic compression fitting that connects the city water element from the actual cold water supply pipe.
Remove the old fitting.
Clear away the old putty tape from the exterior. Use new putty tape on the new city water fitting you have purchased at your local RV store.
Bolt the whole thing back together and remount using the three screws you first took out.
20 minute job once you figure it out.
Good luck.
JSGlow
John, Stacey, Sarah, and Jack
2002 Ford Explorer (EB) 4.6L V-8, 3.73
2004 Antigua 215sso
1999 Starcraft Starfire 160DC
