RV.Net Open Roads Forum: Class A Motorhomes: Vintage Recommendations
 > Vintage Recommendations
Daveinet
il
Posted: 05/22/08 11:53am Link  |  Quote  |  Print  |  Notify Moderator
arcsum68 wrote:
There is an Apollo for sale, seller said the same things, solid wood cabinets, solid frame, ect.
Delamination? Is that the fiberglass peeling away?
You will see delamination as a large bubble area in the fiberglass, where it is no longer flat. If you push on the bubble, it will probably feel soft. often seen under windows - it is the result of water leaking in. Just to clarify, some coaches will have a slight wave to the walls because the wall is not a laminated type wall. This does not mean anything bad.
Yes, I would add Apollo to the list. We often forget about them because it was a smaller company. '85 was the last year for Apollo, as they were bought out by Revcon. You may see later years, but those are built with left over parts, so technically are older than the title date. If you can handle an engine rebuild, then go ahead and give Revcon a serious consideration. Price is usually low because few know what they are, so it drives down the price. The company is no longer in business and the custom FWD scares people off. All wear parts are available off the shelf from the local auto parts stores, you just need to know what to ask for. The comment I often hear is those who bought them chose to because it was the first old motorhome they stepped into that didn't smell. If you are willing to shop, you can probably find one in good condition well under $10K. You will see some fixed up for more, but a pretty good one can still be had for less if you shop. I spent two years to find this one.
Dave
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Thorley's & Magnaflows,
Howell/Edelbrock MPFI, Koni FSD,
Class A built for gear heads
My Revcon Website
Revconeers Forum
XP activation frustration
enblethen
Moses Lake, WA USA
Posted: 05/22/08 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
OP:
Your use of the word "vintage" is drawing some ideas for true antiques.
Daveinet:
Good answer on de-lamination.
OP:
de-lamination happens along roof line, around comparment doors and below windows.
Bud
Suzuki XL7 pushing Pace Arrow
LVJ58
Las Vegas, Nevada
Posted: 05/22/08 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
We sure liked our old 84 Airstream Classic
Jim & Sherry Seward, FMCA #F342207
2000 Residency 3790 V-10 w/tags
2003 Suzuki XL/7 Towd
Big Katuna
Deland, FL
Posted: 05/22/08 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Another vote for something with fuel injection, which started very late 80's, early 90's. Holiday Ramblers where aluminum roofed and well built.
My Kharma ran over my Dogma.
Joatha
Marietta, GA
Posted: 05/22/08 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
Bluebird Wanderlodge.
Start and stop there. If you want vintage, they don't come any higher quality in terms of vintage.
Daveinet
il
Posted: 05/22/08 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
To keep this in perspective, TBI (throttle body injection) does not vaporise the gas as well as a carb and therefore is less efficient. The only advantage to TBI is cold starts and high altitude compensation. Otherwise a carb will out perform TBI. If you want efficiency, you need MPFI, which is '96 or newer for GM. TBI is not a bad choice, but just keep in mind what advantages you are comparing.
Gale Hawkins
Murray, KY
Posted: 05/22/08 11:16pm Link  |  Quote  |  Print  |  Notify Moderator
Dave your info would explain then why 454's in boats kept the carbs right into the mid 90's.
Big Katuna
Deland, FL
Posted: 05/22/08 11:29pm Link  |  Quote  |  Print  |  Notify Moderator
Carbs suck. A perfectly new, well tuned carb might deliver more HP on a given day but any kind of processor controlled EFI is better than a carb for reliability and efficiency. I have had them all and carbs need tuned, coddled, and fed.
Are you saying the OP would be better off buying a carb motorhome over a newer EFI motor with a four speed trans with OD?
Puhleeeeze!
v8q
Oviedo, FL
Posted: 05/23/08 04:29am Link  |  Quote  |  Print  |  Notify Moderator
Blue Bird, Foretravel/Travco, FMC (Parliament coach in St. Pete has a nice one for sale). GM, the right Vixen... There are lots of options. Some darned good coaches made back then.
Key would be what successive owners have done to 'upgrade' them, what has been replaced (reefer, AC units?) what the engine condition is and the overall body condition. Could be a maintenance and/or trouble shooting nightmare...
Dave Head
Oviedo FL
95 Foretravel U320C SE
M11, HD4060
Hurricaner
Hurricane Utah
Posted: 05/23/08 06:08am Link  |  Quote  |  Print  |  Notify Moderator
I hate to say this but where gas prices are heading if you can only afford a 5000 dollar motorhome you just can't afford one. An 80s class A probably gets 5-6 MPG so you soon could be paying a dollar a mile just to drive it. A 500 mile trip will cost 500 dollars just in gas. If you lose a reefer, there goes another 1500 bucks. These things are not cheap to own or operate.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
