RiverkernB
California
Advise please: leveling blocks or ramps. Which is easiest to use and store for a B?
DutchmenSport
Indiana
I don't have a "B" but I would think the Lego style leveling blocks would be the best for you. They are small, compact, and don't weigh much.
I carry boards in the TT. They are long and heavy, but SOLID! And I can build up one side of the TT as much as 12 inches if I need to. There's always a reciprocating law of give and take. Although very durable and and will work for almost any situation, they are very heavy.
I suggest for your "B" the Lego blocks.
Good luck!
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
jjson775
We carry the plastic leveling blocks but frequently don't need them. With a Class B you can often move around some in the campsite and level up adequately. The refrigerator is the critical issue. My wife puts the little bubble level on the counter top and lets me know which way we need to move. If we can't get it approximately level, we use the blocks. Hope this helps.
Jim
ennajean
Wisconsin
We bought some of the lego type blocks and have only used them once so far. But it's nice to have them if needed. Dont take up much room in the B.
Anne and Dick
DABEE a 2006 Ford Sportsmobile Penthouse top.
rockhillmanor
On the Road
Leveling blocks are lightweight and easy to store in the bag they come in, they fit in my smallest bay.
Don't buy the open weave ones they break. Get the solid ones.
A little square flat bubble level placed on the dog house between your cup holders when you start to park, can eliminate about 80% of the times you would have normally had to level the RV.
Just moving around a bit while you are still behind the wheel using the flat bubble level as a guide WILL find the level spot within most sites.
The best $3.00 I've spent so far for the MH.
edited 05/22/08 05:54pm by rockhillmanor *
31 ft Four Winds
Chevy Tracker 4x4 Blue Ox
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
Dick_B
Palos Heights, IL USA
Whatever is used for leveling be sure to support the ENTIRE footprint of the tire otherwise the tire may be overloaded in that section that is on the narrow blocks.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Gotagetgoing
Maryland
I have two sets (20 blocks) of the Lynx blocks and have recently had to use all of them to get level. I also have one stop block that they sell. The blocks are easy to store because you can spread them around in the RV where ever there is space. This is important in a class B. Also you can use more on one side as the situation calls for. I never had one break in three years that I have been using them. I do think that they are over priced however. On soft ground they sometimes sink in and I wish the company would put out a solid block for the bottom layer.
Dick
Islandman
NW Washington
Leveling blocks are yur best bet, we have two sets just like Gotagetgoing and used both sets a couple times last month when sort of boondocking. Cracked one of them when we set up in some soft ground. What I like about the blocks is that you can adjust to different heights and the fact that they store easily. Got our blocks at Camping World.
What Next
Northern IL
I guess I'm different, had the blocks wished I had two sets now I have these and love them.
ramps
2005 LTV
Rodger
Tucson, AZ.
The "Fiamma Level Up Plus" ramps, that What Next has, are the best. That's my opinion.
Level Up Plus with chock.
last
edited 05/22/08 10:46pm by Rodger *
View edit history
Visit My Roadtrek
Hey, check out the new RV.Net Blogs!
