RV.Net Open Roads Forum: I'm not really breaking my own rule but.........
 > I'm not really breaking my own rule but.........
F.L.U.F.
Cedar Rapids Iowa
Posted: 05/22/08 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
My personal rule is not to start or read posts about the high price of fuel but this is a little different.
During a recent trip to Elkhart IN I decided to check the mileage of my 2000 HR with Freightliner chassis, Cat 3126, and Allison 6 speed trans.
Here's what I did... I drove a steady 60 mph across Eastern Iowa all of Illinois and half of Indiana. I was very diligent to keep the speed at 60 all the time over there and back. When I got home and filled up I was very disappointed in the 7.2 mpg I got on the trip.
I mentioned the trip to my BIL who has the exact same rig as mine with an Itasca house on it. He told me his coach will not shift into 6th speed until it hits 63 mph until then it stays in 5th. and the RPM's will be around 1800-1900 in 5th they drop to 1650-1700 in 6th.
Well I just couldn't let that info set and ferment in my brain so I took the coach for a little 360 mile trip today. Needless to say I was very surprised at the outcome..... I never let the MH go below 65 mph for the whole trip. At 65mph the fuel mileage jumped to an amazing 8.8. My RPMs did drop to 1650 and to confirm it was in 6th gear all the time I shifted it into 5th manually a couple times to make sure.
Because the shift indicator shows 6th gear all the time I just assumed it really was in 6th gear but that is not necessarily true with my Allison 6 speed trans.
Anyone ever try this test? or discover the same result as I did?
Keep Smilin' It Makes Everyone Wonder What You Are Up Too!
BlackSilver
East of Heaven, North of Hell
Posted: 05/22/08 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
I have a six-speed Allison, but in a 1-ton pickup. It grabs 6th gear (on level ground) at about 60MPH (about 1500RPM), and the mileage is SIGNIFICANTLY better than at 59MPH in 5th gear!
Hans, KØHB & Colleen, KØCKB
Master Chief Radioman, US Navy
'04 Prairie Schooner 34FBR Platinum XL Camping Trailer
'08 3500HD Silverado Big Dooley LTZ Go-power by Max & Allie
My rig (Click)
mavapa
Rome, Ga, USA
Posted: 05/22/08 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
Very interesting result. I wish the indicator showed the actual gear.
gm seller
holland ny
Posted: 05/22/08 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
ditto you really have to watch the rpms to see it go into 6th gear
2006 GMC Sierra SLT 2500HD crew cab 8.1 with 6 speed allison
2007 Keystone Laredo 32rs
Myself, Darling wife Lisa
Laura 16,Sara 13
2 Jack Russell's
Jack & Rusty
Dog Trainer
Richmond Mi.
Posted: 05/23/08 05:57am Link  |  Quote  |  Print  |  Notify Moderator
I noticed the same thing with mine. It does not shift into 6th untill over 63 but will stay there down to about 60. My mileage is better when in 6yh gear. so 55 for me is no better or a little worse. I have an older 93 allison 3060 and my touch pad shows gear selected on one side and which gear you are in on the other so I know at all times which gear I am in. I wonder why they would have changed that.
93 Airstream 35' Dp
5.9 230 uprated to 300 HP
Allison MD 3060
Dutchess and Shadow (fur Bearing Children)
spitfirepete
Great Outdoors RV resort
Posted: 05/23/08 06:41am Link  |  Quote  |  Print  |  Notify Moderator
If you are not sure what gear you are in use touchpad to select 5 and see if it downshifts...then go back to 6
Peter and Linda
2007 Mandalay Presidio ISC
1975 Triumph Spitfire toad
2007 Saturn Vue toad
Bichon and Cocker (spoiled puppies)
awjoker
Ohio
Posted: 05/23/08 08:27am Link  |  Quote  |  Print  |  Notify Moderator
For optimal fuel economy (on any vehicle) it is better to observe the tachometer than the speedometer. Taxing the engine is what burns the fuel, not driving at a particular speed. Keep the tach as low as practically possible.
2006 Dodge Ram Quad Cab, HO Cummins, 4x4
2000 Sunnybrook 26FK
2006 Stock Trailer
1996 Car Hauler
apr67
Tallahassee, Florida
Posted: 05/23/08 10:58am Link  |  Quote  |  Print  |  Notify Moderator
The best thing to watch would be the fuel flow meter. Not standard issue on cars as of today, but I doubt it will be long. Boats with largish engines usually have flow meters.
Don't take your organs to heaven. Heaven knows we need them here.
2007 National Surf Side 34DE. Full timing since 1/06/08
2007 Toyota Matrix Da Toad
F.L.U.F.
Cedar Rapids Iowa
Posted: 05/23/08 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
I would never have guessed the indicator shows 6th gear when it may still be in 5th. Now that I know I can keep an eye on it and start getting better mileage.
Kind of makes me feel dumb that after all these years I didn't know. After 47,000 Plus miles I would have figured it out.
MartyAndPeg
Jacksonville, FL 32204
Posted: 05/26/08 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
We have a device called the MIS (Medallion Instrumentation System) which is pretty common on Freightliner XC chassis, and keep it set to the E-Info screen, which shows speed, RPM and current gear.
I'm not sure what speed I have to be running before it kicks up to 6th gear, but I am sure it is not 63. We will leave Raleigh, NC on Wednesday (continuing our northern trek) and will keep an eye on when the shift occurs (and the raod conditions).
Marty & Peg (and 2 cats)
2005 Tiffin Phaeton 40QDH/350HP Cat/MH3000
2007 Ford Ranger XLT 4x4/Brake Buddy
2007 Harley Davidson Softail Custom
Full-Timing-7 years and counting!
Looking for a purpose in life, try Habitat for Humanity RV-Care-A-Vanners!
