RV.Net Open Roads Forum: Folding Trailers: turn on Refrigerator at home...?
 > turn on Refrigerator at home...?
out#d-butoutside
S. Florida
Posted: 05/22/08 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
We’re leaving on our 1st trip tomorrow!!!!
I want to turn the refrigerator on tonight to get it cold.
I thought it would be easy but truth is, I JUST DON’T KNOW HOW!!!!
I thought I could just unplug it from the outlet IN the trailer and use an extension cord to plug it into the house. Is that it?
Ummm…… Now what?
It started getting really hot back there. I don’t know if it should. Too afraid of waking up to a fire.
Do I need to flip a switch or anything?
What are the steps for turning it on? I can’t figure it out from the manuals.
Dometic model rm2193
Flagstaff 206Ltd
M
“Life is uncharted territory. It reveals its story one moment at a time.”
The snow man
green bay, wisconsin
Posted: 05/22/08 10:44pm Link  |  Quote  |  Print  |  Notify Moderator
Just plug your unit into electric and turn the fridge on..It should take care of itself...When I leave home for the trip I switch it over to LP and leave the fridge on as we travel...
bldrbuck
Boulder, Colorado
Posted: 05/22/08 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
Just to cool the fridge you should be able to plug into a 15 amp outlet and it should work fine. Using propane with the unit plugged in may be a bit faster for cooling down. You need 12 volts so plugging in charges the batteries. Good luck.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
He Ruide
Cincinnati Ohio
Posted: 05/23/08 05:27am Link  |  Quote  |  Print  |  Notify Moderator
Melissa, Yes you can unplug the fridge from the PUP and plug it into a extension cord. On this photograph you will see the switches for the fridge. Make sure the propane circular knob (on the left) is turned off and then push the large green knob on. The circular knob above the 120 and 12 volt switches regulates the temperature. Turn it to 5, 6, or 7.
Hope this helps.
Ruide
Fleetwood Evolution E3 - Yellow (DW let me get a Yellow one since she wanted an E3 with a slide out )
Hummer H2 - Black (DW vetoed the Yellow one, but I got two Yellow Hummer Folding Mountain bikes )
My Pics and Mods and My Weekly Blog
out#d-butoutside
S. Florida
Posted: 05/23/08 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, to all, for your help. We're up and runnin'
M
