RV.Net Open Roads Forum: Class A Motorhomes: Hydralift motorcycle lift
 > Hydralift motorcycle lift
BerkshireVille
Burlington Ontario Canada
Posted: 05/26/08 07:11am Link  |  Quote  |  Print  |  Notify Moderator
I just put a Hydralift on the Berkshire. Works great. I had it installed by the shop recommended by Hydralift. They told me the Hitch House does beautiful work, great installs. Total BS. Hydralift has a great product, but are just trying to sell lifts in the end. The qualified installer charged me $300 to relocate my rear hanging mud flap. Good thing he was too lazy to cut the bolts that were 3" too long off. Since there was no loc tite, no lock washer, no double nut it vibrated loose and my mud flap was dragging on the ground on one side. An easy fix, but by no means a beautiful install.
Check your clearance for the door to your motor. Mine swings out and then up. As a result the lift is 6 or 8 inches farther out than all the pics I saw on the web site. Not a big deal but when I do pull my trailer there is 6 feet from the back of the RV to the front of the trailer.
It is really nice to use. Easy to load, very secure while traveling, and the perfect height to change your oil! PM me as well if you'd like some pics or more info. Adam.
2007 Berkshire 360QS MBE 926
KTM 990 Adventure
Spur Of The Moment
Anywhere, USA
Posted: 05/26/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
In my opinion it's the best lift out there. We haul an 850 lb. quad. Installed at Cliff's welding in Mesa, AZ.
Nascar fans
Bruce and Sharon and Gizmo(Apricot Tiny Toy Poodle)
'07 Beaver Contessa Venice 43' Quad Slide
Roadmaster Chassis 400 Cat
2001 Jeep Grand Cherokee
'08 Polaris Sportsman 500 Touring Quad on a HydraLift
dav5942
Stuart, FL
Posted: 05/26/08 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
WA1RI wrote:
Just got a used Overbilt. Need to get the recivers welded on now.
Hydra looked good, but this one was almost free. Tested and works fine, it uses the cable to lift.
Make sure you have a knowledgable hitch man weld/bolt the receiver to the frame. We had to extend our frame 3' on the Bounder or else the lift could pull the entire rear cap off-which we have seen happen on improperly installed receivers.
2007 Newmar 42' Mid Engine w/Fatboy,ATVs-in Garage,lifted Jeep(s) in tow, Hog Valley Florida(a diamond in the rough),'09 Alaska again!
2007 Tour Alaska Fishing '08 Tour Grandchildren Newmar Mid Engine
harleylover200
Spring Hill, Florida USA
Posted: 05/27/08 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Hello everyone, looking to put one on my 2007 Bounder 35E, Gas
I have already reinforced the hitch area, all the way back to the hitch, didn't like the fact the frame didn't go all the way back.
I'm towing a car trailer with the MC on the front of the trailer and a jeep on the back. Works ok, but would like to put a lift on and flat tow a car.
thanks.
Kurt and Pat
Harley and Elliott and Kasey(yorkies)
2007 Fleetwood Bounder - 35E Workhorse
6 Speed 496 Cubic Inch V8 - W22
2003 Ultra Classic - 100th year
William B
Atlanta area right now
Posted: 06/03/08 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Just had the Hydralift installed. Visone in E. Bernstadt, KY did a fantastic job! Looks just like the factory had installed it. Works great, going to use it for the first time this weekend. An absolutely quality item.
Full-Timing
2007 Holiday Rambler Navigator
2006 Jeep Grand Cherokee
2007 BMW R1200RT on Hydarlift
thunderstruckhd
Ft.lauderdale,Florida
Posted: 06/03/08 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
After looking at all the lifts available, I personaly like the Cruiser Lift the best. I like the lift so much I sell and install them...
2006 Allegro Bus, 42QDP, Tag axle, 400ISL.
William B
Posted: 06/08/08 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Well, after our maiden voyage with the Hydralift, WE ARE SOLD! Fantastic! Didn't even know it was there. The bike rode great, the lift works perfectly. Easy to load and unload. A super quality item that is worth every penny.
WA1RI
FL
Posted: 06/09/08 05:22am Link  |  Quote  |  Print  |  Notify Moderator
My welding shop told me not to do it. The Ford frame ends and he would need to extend it all the way back. My axle is about 10' in front of the bumper, so hanging 1000 pounds that far back wouldn't be good.
So, now I have an Overbilt in Zephyrhills available.
Looking for the tow dollie that carries the bike on front.
Bill & Jolene / FL
1997 Southwind 35P
2006 Yamaha 1100 Classic &
1970 Norton Commando 750 in state of recuperation (Almost road ready!!!)
6x12 Enclosd trailer
