RV.Net Open Roads Forum: Truck Campers: Anybody making thier own diesel?
 > Anybody making thier own diesel?
mowermech
Billings, MT
Posted: 05/24/08 09:58am Link  |  Quote  |  Print  |  Notify Moderator
HedoTravelers wrote:
mowermech wrote:
Just remember the tax man. It is illegal to run untaxed fuel for road use.
It's a non-issue. Call it experimental.
I hear the fines can run upwards of $10,000 for running untaxed fuel on the highways. good luck with the "experimental"!
Remember, it is BOTH State and Federal taxes.
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, Std. cab, LB, 5 speed, 4.10 LS diff., Jacobs Rambrake, 273,000 Miles
'99 Monaco McKenzie 32' triple slide
'95 Tioga 29H Ford-based Class C
Daily driver: '06 Jeep Liberty CRD
Towed: '06 Jeep Rubicon Unlimited
Matthew_B
The boonies near Dallas, Oregon
Posted: 05/24/08 10:50am Link  |  Quote  |  Print  |  Notify Moderator
I hear the latest source of biodiesel is from sewage treatment plants and grease traps at restaurants and schools. At the treatment plants, they are able to separate the floating scum that's rich in greases, fats and oils.
There is only one problem: When you burn biodiesel from McDonald's, it smells like french fries. When you burn biodiesel from KFC, it smells like fried chicken. Guess what this stuff smells like?
The solution is they are intending to blend it into dino-diesel at the fuel rack with no more than 1% concentration, where it can't be noticed.
russd
northern az
Posted: 05/24/08 11:33am Link  |  Quote  |  Print  |  Notify Moderator
my friends brother sells a machine that does most of the work for you. he says he can do 50 gallons in 48 hours with about 20 mins of his time involved. not counting collecting the oil. down side is this machine costs 7k. i don't drive enough for that price. fusionbiodiesel.com is his website. seems like everyone i read about or most anyways say their truck runs better on bio.
russd
  • 2003.25 f350 cc sb 4x4 6.0/torqshift 06' artic fox 811
  • photos
  • PJ Colahan
    Antioch, CA
    Posted: 05/25/08 10:39am Link  |  Quote  |  Print  |  Notify Moderator
    Northern Tool has a unit that you can buy that will process the cooking oil into bio diesel. Kind of expensive at $8K but if you travel a lot it could pay for itself.
    As for the fuel tax. That applies to fuels produced by refineries. There are two types of diesel, commercial/agricultural and highway. The Highway fuel has a dye in it to identify it. The law is so that you cannot use the agricultural fuel which is sold without a lot of additional taxes in highway vehicles.
    armpics
    New Providence,Pennsylvania
    Posted: 05/25/08 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
    From the research I've done; bio diesel made from used vegetable oil is cleaner and better for your engine . The process is supposed to be easy enough to do in your garage. A processor can be made out of a old water heater for a couple hundred dollars,or a prefab unit for anywhere from about 2 grand to 8 grand. With all the innovative people on this forum I guessed that there would be a few making their own fuel already, I guess I'm in front of the curve for a change. which is good because from what I've read the free used oil gets hard to find once it catches on in an area.
    2004 Dodge DW 3500 diesel 4x4, airbags & ranchos, Arctic Fox 1140 dry bath,48" super hitch
    sleepy
    Oak RidgeTN
    Posted: 05/25/08 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
    When you make moonshine experimentally you go to jail... tax evasion.
    When you put off road diesel in your truck and drive it on the highways you are breaking the law.
    The only place that you can legally use homemade diesel is for off road use.
    I'm sure that some over zelous tax man would like to make an example out of you.... even worse someone you know would probable turn you in for having 50 gallons of FREE diesel when they had to pay almost $450 for the same amount.
    You probably don't use 50 gallons a week now... you'll be tempted to sell some or at least share. DON"T
    My advice... if you are going to do it... don't talk about it... don't write about it...just quietly do it.
    Good luck.
    2003 Lance 1161/ dinette slideout/solar cells/propane generator/Sat dish/2 Fantastic Fans model 6150/AC/winter package
    Chet's AirFoil, Trimetric, LED lights
    2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
    sirdrakejr
    Las Vegas, Nevada
    Posted: 05/25/08 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
    California is already going after the makers of their own juice. No one gets away now. What a thing to do. First they ask for help and then go after you if you try.
    Frank
    RV.net blog
    For those of you looking for expert advice, here ya go!
    Frank
    sleepy
    Oak RidgeTN
    Posted: 05/25/08 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
    I think you have it backwards:
    Off road diesel has the dye in it.
    If your fuel tank has dye in it you are in trouble. I'm told that the dye is very hard to get out of your system if you should every use it even just once
    Redneck bling
    New Jersey
    Posted: 05/26/08 04:48am Link  |  Quote  |  Print  |  Notify Moderator
    To make bio diesel you need to heat the oil and add Ethel alcohol and lye...two very flammable and caustic chemicals. Then the oil separates to bio diesel on the top and glycerin on the bottom. You then need to cook and aerate the alcohol off. Its a pretty serious operation. Research it better and see what your getting into. There are a lot of sites devoted to it. You need to get rid of the glycerin and the bio diesel needs to be burned after warm up and you need to convert back to diesel prior to shut down. Its also temp sensitive as in it gels sooner than diesel. Meaning you need to have a separate tank for it. That's why its mixed so often with diesel. Now for the big wham....less BTU's per gallon so if you get say 16 mpg on diesel.....you will get maybe 13 on pure bio diesel with the wind at your back. Like I say....research it good. Cost of alcohol and lye....the electric for heating it.....the glycerin waste......for less mpg range. Also.... biodiesel is like a solvent and you WILL have to replace your fuel filter 3-4 times. Its amazing how much stuff frees up and travels the lines. I'm not anti bio diesel....it's just too much effort and contamination risk for me what with children, dog's and fire risks.
    99Ford F250crew,shortbed,4X4,autotran,7.3Dsl,4"exh/air/gauges/dp chip/Mich265/75R16/E/camp pkg-(anti sway front&rear w/helper leaf)/firestone ride rights,Bilstien shocks.
    06 Lance 861/loaded/Honda 2000 generator.
    Everything working well, so far/so good!
    silversand
    Montreal
    Posted: 05/26/08 07:17am Link  |  Quote  |  Print  |  Notify Moderator
    ....wow! $8,000 for a biodiesel conversion unit, + $6,000 for a diesel optioned truck...I'd say: fergit diesel, Buy a filling station instead
    Cheers,
    Silver-
    Silver
