RV.Net Open Roads Forum: Travel Trailers: A/C smell
 > A/C smell
H & E
North Texas
Posted: 05/24/08 05:11am Link  |  Quote  |  Print  |  Notify Moderator
We are in southern GA and last night I noticed a musty smell when the A/C came on then again this morning. Is there anything I can do to get rid of it. Thought about spraying Clorox in intake but not sure what other damage would result.
Polishnurse
Schodack, NY
Posted: 05/24/08 05:42am Link  |  Quote  |  Print  |  Notify Moderator
Don't spay Clorox in there. The musty smell is condensate siting in the unit. You might try som Zap Tabs form Home Depot. It's a tablet that is made for that musty smell. You will need to take the grill down to get in there. You might also need to cut it in Half. I will last for a few months. Good Luck and happy camping. JM2Cents Bill
axle234
Pasadena,Md.
Posted: 05/24/08 06:19am Link  |  Quote  |  Print  |  Notify Moderator
I have used FrigiFresh before and had success.
http://www.bgprod.com/products/climatecontrol.html
axle234
2008 Fleetwood Fiesta
Toad- 99Honda CRV
javaseuf
Southern Cal
Posted: 05/24/08 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Also be sure the drain pan on top isn't blocked with leaves and debris. If it is, the conensation will pool and begin to smell.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
jesterdog
Posted: 05/24/08 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
Spray Lysol has worked well on car a/c smells. If you can spray it up in there to kill the mold and mildew...Soak it down!!!!
2001 Excursion 3.73 geared V-10
2006 Coachmen Spirit of America 24TBQ
wrenchbender
Phx
Posted: 05/24/08 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
Jesterdog is right on.I spray nine thru the evaperator drain with garden sprayer.
H & E
North Texas
Posted: 05/24/08 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
jesterdog-Also be sure the drain pan on top isn't blocked with leaves and debris. If it is, the conensation will pool and begin to smell.
I went up on the roof and the A/C is at the low spot and the roof around it has about 1/4 inch of water. Slanted the TT a little and it is running off in an almost steady stream. Seeing that makes me think the drain is working.
Thanks
H & E
 > A/C smell
