RV.Net Open Roads Forum: Tech Issues: Refrigerator no working on gas
 > Refrigerator no working on gas
whitetruck
Boulder City Nevada
Posted: 05/24/08 05:42am Link  |  Quote  |  Print  |  Notify Moderator
On a new for us 02 wanderer model 192, we are unable to get fridge to work on gas. Works on electric fine. Seems to want to start but when letting of the start button the "ON" light goes out. Can hear the auto started going and when start button is pushed can hear the gas light up. How does one blow out the lines? Have plenty of LP gas and stove works fine.
bob and jackie
2007 Jayco 341 5th wheel 4 slides 14000 lbs gvwr
2002 Wanderer 192 HTT
2004.5 Red QC CTD 11500 GVWR 3500 dually LB AUTO 3.73 325/600 Prodigy brake controller magnaflow
1999 Chrysler LHS
RPFAN
Poughkeepsie NY
Posted: 05/24/08 06:24am Link  |  Quote  |  Print  |  Notify Moderator
Is this the 1st trip out this year? If it tries to light and goes out, there could be insect/spider has moved in to the burner. You would have to clean it and try again.
Rich
Rich, Fern, Bethany, Justin. 2005 Ford F450,Lariat, 6.0 PSD,CC,DWR,4WD, Air Hitch, 100 Gallon Aux fuel tank.
2009 Cardinal 3802BH 5 slide, on order!
Our "Condo in the Woods"
Leave no roller coaster unridden!
bldrbuck
Boulder, Colorado
Posted: 05/24/08 06:38am Link  |  Quote  |  Print  |  Notify Moderator
Clean the burner and orfice. Use only compressed air and alcohol to clean the orfice. Do not probe it with anything.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
Bill/Diana
Southeastern Pennsylvania
Posted: 05/24/08 07:16am Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem and cleaning the propane line did not remedy the situation. I had to replace the circuit board with a Dinosaur product. Click here for a link for replacement circuit boards. Refrig has worked great since. Easy procedure to replace the board and takes about 20 minutes....start to finish.
Also, click here for more refrig help.
Hope this works for you.
Bill & Diana
Please click here to visit our Website
Keith M
Cle Elum
Posted: 05/24/08 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Blow it out as mentioned with compressed air. Thats the first thing they do if you were to take it to a shop. I would also check all the wiring to the circuit board. The circuit boards tend to fail after about 5 or 6 years. Thats probably why Dinosaur Electronics does such a good business manufacturing replacement boards. I think that even if the compressed air does the trick that within two years you will be looking at replacing the board.
h2guy
Ain't seen a sign yet!
Posted: 05/24/08 10:11am Link  |  Quote  |  Print  |  Notify Moderator
If its like my hot water heater, then the "On" light is SUPPOSED to go out when the burner begins operating.
After to switching to gas, and the light goes out, have you gone outside and verifyed that the gas is not lit??
Rick & Carolyn
01 Ford SC 4x4 DRW
01 CarriLite 5ver
Kenneth
Washington, the state
Posted: 05/24/08 10:14am Link  |  Quote  |  Print  |  Notify Moderator
As h2guy says, take a good look at things. Remove any draft shields that block your view of the burner and see what's happening. I've seen the burner tube get crudded up so it didn't spark--a touch with some sandpaper fixed that. I've seen the electrode get shaken out of position so it didn't spark right. Take a look. See if the burner will light and burn when you use a flame to start it (be careful!). See just where the spark is hitting, if it's sparking at all.
TandA-n-Mac
new jersey
Posted: 05/24/08 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
i had the same problem on 92 TT. yes clean burner with air and as i do with everything give it a good smack. i had to also replace circit boards i found a used parts place, and replaced both boards inside with controls and the board within the outside copartment.
06 F250 6.0 TD,SC,SB,4x4,Towboss,3.73 rear.Firestone air bags,285/70 R17 3795lb tires,18000 slider; 04 38' Jayo Designer "Legacy" 5er; all I need now is satilite TV and hit the lottery; NAVY,"WE'LL NEVER FORGET,land of the free because of the brave"
racefan1965
Redding, Ca.
Posted: 05/25/08 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
Had same prob....one dinosaur board and a good cleaning later and it works great!
Rick, Shirley, Lacy, Misty and 2 dogs(Shasta & Baylee)
1999 Dodge 2500 Quad Cab 4X4
1984 Alpenlite24 5er
1988 Coleman pup
2006 Champion C46540 RV plug ready genset
