RV.Net Open Roads Forum: Fifth-Wheels: blackwater tank
 > blackwater tank
Mickey C
alabama
Posted: 05/24/08 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
hi, not sure that i'm asking this in the right place but here i go. I have a 2004 sprinter by keystone ( 29 ft.--5th wheel ) I have been living in it for 2 years without any problems & then all of a sudden my toilet backs up & clogs up. I dump the tank but no help, still clogged. I buy a snake & run it though the commode but no help, I put chemicals in it to dissolve the clog & it clears, 2 days later its back. this has been a continuing problem for a couple of months now. I have one of those systems to flush out the tank, the tank seems to be empty but the toilet is clogged up & full of sewage. Can someone tell me about how long the pipe is that runs from the toilet to the tank ( it doesn't drop straight down ) & is there some sort of vale or anything that could be causing this problem. Thanks
DSINCA
CA
Posted: 05/24/08 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like you our at the point were you need to spend a few dollars and have a dealer or RV repair look at it.
You can't take the Fisherman out of this Camper
Ontario, Canada
Posted: 05/24/08 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
Mickey C wrote:
I put chemicals in it to dissolve the clog & it clears, 2 days later its back. Thanks
Do you mean it is clogged up with sewage in two days... after it has been cleared??? How many people are using this thing???
Seriously, are you saying that the tank wasn't really cleared and that's why it is plugged again in two days? There is the slight chance that the plastic cutout from the installation of the toilet was left inside the tank and is now at the tank outlet, blocking the contents from fully unloading. The only way to find out if that's the case is to have a sewer contractor who has a camera snake take a video picture to find out if that's the problem. If it is, then the next thing you will need to do is figure out how to get it out!
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: FINALLY... 2002 Cougar 276EFS; 2002 GMC 2500HD Ext Cab 4x4; (Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
outdoorsman2007
In the Woods - Somewhere!
Posted: 05/24/08 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
The pipe from the toilet to the black tank is 3 to 4 feet long.
skipnchar
Topeka Kansas USA
Posted: 05/24/08 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
It actually sounds like you MAY have been skimping on water use when flushing and/or dumping when it was not full and/or leaving the black tank OPEN when hooked up to sewer. Any of these things can cause a sludge build up which can turn to rock like solids causing multiple clogs as you describe. Easiest way to fix NOW may be to hire someone with a honey wagon to flush out your tanks and start over making sure you follow proper care for the black tank. Remember it takes a lot of liquid to flush solids across the horizontal surface of your black tank. Good luck / Skip
Mickey C
alabama
Posted: 05/25/08 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Skip, what is a honey wagon?
eend
Alberta
Posted: 05/25/08 10:42am Link  |  Quote  |  Print  |  Notify Moderator
A honey wagon is a sewer truck or a liquid manure wagon, this is what the farmers used to call it. Sewer/manure smells sweet and honey is sweet. get it??lol.
'98 GMC Z71 6.5 turbo diesel
1999 24.5' Prowler 5th wheel
lv2rom
Kansas City, Missouri
Posted: 05/26/08 08:18am Link  |  Quote  |  Print  |  Notify Moderator
I think you have the dreaded "poop pyramid" due to insufficient fluids. I ASSUME??? you know enough not to leave the valve open except when dumping or the fluids escape but the solids don't???
Try putting about five gallons of fluids in there, some Aquazyme (by Thetford), let it soak a little, then....if you can access your black tank go underneath and thump quite seriously on the bottom of the tank. After that take a hose inside, and while someone else opens the drain valve run water through it for a while.
I believe you've just got some solids built up that need to be broken down and washed away and it doesn't take long for the pyramid to reach up to the bottom of the down pipe again each time after you ream it out.....The fix, and the avoidance are the same....
WATER..WATER...WATER...WATER....FYI..Brian
2005 F350 Dually -AFE air box/MRSP exhaust/Bags/Bilsteins/Energy Susp./Michleins
2002 Hitchhiker Fiver 29.5 RLBG - Moryde Pin/Gas shocks/Michelin XPS Ribs
1996 Layton Fiver 21ft. Totally reconditioned..Love it!!
Chefd
Arizona
Posted: 05/26/08 11:33am Link  |  Quote  |  Print  |  Notify Moderator
I have had this problem!
1. Run your flush system to about 1/2 full. Add water to the stool and use a plunger with the stool valve open. This should clear the first pipe.
2. Now open the drain valve and flush the tank with lots of water.
3. Close the drain valve and add water to the tank. Do this until water starts up into the stool. Open the drain valve. You are looking for a surge to help clear the clog. Repeat this several times.
4. If this fails you may have to call a repairman.
Chefd
 > blackwater tank
