RV.Net Open Roads Forum: Fifth-Wheels: Solar Panel Wires
 > Solar Panel Wires
Pete2070
Arnold, Maryland
Posted: 05/25/08 06:18am Link  |  Quote  |  Print  |  Notify Moderator
I have an 08 Mountaineer 345DBQ. I just bought a 15 watt solar panel kit from Camping World to keep my battery charged. Does anyone have suggestions on how to run the wires from the solar panel so they're not hanging outside the 5th wheel? I'd like to run them from the solar panel to the battery keeping it inside as much as I can. I already check the tech section and there wasn't anything there.
Thnaks in advance.
Pete
Pete and Celeste
Grandchildren: Gracie, Carter, Lily, and Audrey
2008 Mountaineer 345 DBQ
2007 Ford F250 Turbo Diesel
STINGRAYRVMAN
PANAMA CITY
Posted: 05/25/08 06:26am Link  |  Quote  |  Print  |  Notify Moderator
I usually go down through the referigerator compartment (be sure to go down the opposite side ofrom the flue tube) and then depending on the unit either underneath the unit to the batteries or if the fuse panel is close by I will connect in to it. Excellant choice of RV buy the way. that is the best bunkhouse 5w there is (just my opinion).
tom_kat
way upstate new york/lake george area
Posted: 05/25/08 07:37am Link  |  Quote  |  Print  |  Notify Moderator
most use the refer vent to run the wires thru.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
jauguston
Bellingham, WA
Posted: 05/25/08 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Reefer vent.
As far North as you live don't expect much out of that little solar panel. When its cloudy you will get nothing out of it.
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
275 RV injectors
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Veebyes
Bermuda
Posted: 05/25/08 11:02am Link  |  Quote  |  Print  |  Notify Moderator
To get to the basement send it down the holding tank vent. You will need to seal the hole real good around the wire after the install. From there to the panel controller & on to the battery bank.
RV: slightly pre enjoyed 2006 Alpenlite 34RLR LTD
2006 Chevy 3500 crew cab LT 6.6L Diesel
SCVJeff
Santa Clarita, CA.
Posted: 05/26/08 02:33am Link  |  Quote  |  Print  |  Notify Moderator
I ran mine down the fridge cavity
Jeff - WA6EQU
fuzzy194
R.I.
Posted: 05/26/08 05:21am Link  |  Quote  |  Print  |  Notify Moderator
Check with your dealer,some of the new tralers are allready wired for solar panels.
STINGRAYRVMAN
PANAMA CITY
Posted: 05/26/08 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Mountaineers aren't pre-wired.
Scarface56
Appleton, Wisconsin
Posted: 05/26/08 07:30am Link  |  Quote  |  Print  |  Notify Moderator
I ran mine down the holding tank vent into the cellar where I mounted the controller, then to the batteries. IMHO The 15 watt solar panel is pretty useless unless you are using it just to keep your single battery charged while your unit is stored.
Just Me & DW
2008 GMC 3500 SLT DRW Diesel
Pioneer AVIC D3 GPS Nav/Stereo/backup camera
2007 276RLS Cougar 5th wheel by Keystone
Scooter Buddy 125
17.5 Crestliner Boat
For those of us who fought for it, freedom has a flavor the protected will never know.
 > Solar Panel Wires
