RV.Net Open Roads Forum: Tech Issues: Help with our Roof Air Conditioning unit
 > Help with our Roof Air Conditioning unit
keesgene
Boston
Posted: 05/25/08 06:49am Link  |  Quote  |  Print  |  Notify Moderator
Wonder if anyone can help, but we are currently out in Bandera, TX in 90deg heat, and our roof unit has decided to stop cooling...
The fan still works and blows air, I cleaned the filter and the fins do not look dirty (the unit has not been used much) and it does not heat up or cool the air it is blowing.
I checked the fuse on the thermostat - and it seems fine. I checked the circuit breakers on the electric panel, and it seems fine. I also tested everything on shore power and the generator, and no difference.
Seems to me that for some reason the compressor/heat pump unit is not kicking in.
We have a 29B Itasca Spirit that has a Coleman rooftop unit installed.
Is there a seperate reset switch for the heat pump somewhere, or a trip switch that I should check? or is this a "Call out the Mechanics on Memorial Day...".
All suggestions will be appreciated.
fireman50
Tennessee
Posted: 05/25/08 07:50am Link  |  Quote  |  Print  |  Notify Moderator
Gonna have to call a mechanic. It could be low on freon, the compressor could be bad, or it could be something minor like a startup capacitor.
Kenneth
Washington, the state
Posted: 05/25/08 07:55am Link  |  Quote  |  Print  |  Notify Moderator
Have you looked on top? No, it won't be low on Freon. The other heat exchanger, the condenser, could be dirty or that fan could have failed. Or, as fireman says, it could be a failed capacitor or the compressor itself.
Ramblin_Mo
Mid-Missouri
Posted: 05/25/08 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Check on top
http://blog.rv.net/2008/05/08/tech-tune-up-your-rooftop-ac/
pulsar
Lewisville, NC
Posted: 05/25/08 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
