RV.Net Open Roads Forum: Travel Trailers: adjusting slide mechanism
 > adjusting slide mechanism
rvdogette
SW Louisiana
Posted: 05/25/08 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Hey, I have read here on how to adjust our slide out, but still need explanation. On the inside of our TT the interior trim does not fit flush on one side which is causing some dampness when it rains. Please see the pictures I have posted and tell me which part of the slide we need to adjust. TIA
This bracket looks like it used to be adjusted higher.
This bracket does not look straight.
The carpet curls in and you can see where the trim piece has gotten wet and swollen up. We have replaced this trim board once already thinking it got wet from a rain when I had the slide partially in, not noticing the slide was not flush when extended out instead.
Like I said I did a search already and found some tips, but just not comprehending. Thanks
* This post was edited 05/25/08 04:13pm by rvdogette *
2005 Keystone Springdale
1 Hubby
2 boys 20 & 19
2 sweet dogs, spoiled rotten
Isabella we had to let go due to old age, just prior to her 17th BD.
Sara who we lost from a sudden illness. She was the best camping dog.
A new grandbaby puppy GS, she is a sweety
milzat
Louisiana
Posted: 05/25/08 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Synchronizing the slide room
Fully extend the slide-out, then retract it about 1/2".
Loosen the synchronizing bolts on the side of the slide-out that is not sealing correctly.
From inside the trailer, manually push the slide room outward until the inner seal just contacts the wall, then tighten the synchronizing bolts.
Move the slide in and out a couple of times to check.
Re-adjust if necessary.
* This post was last edited 05/25/08 04:43pm by milzat *   View edit history
milzat
Louisiana
Posted: 05/25/08 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
Vertical adjusting bolts
Fully extend the slide room.
Place a jack under the slide room frame to hold the weight of the slide room. If the slide room is level, do not raise or lower the jack.
While the jack is supporting the weight of the slide room, loosen the two vertical adjusting bolts.
Straighten the slide mechanism and re-tighten the vertical adjusting bolts.
Test the slide room travel.
rvdogette
SW Louisiana
Posted: 05/25/08 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Great, thanks a bunch.
rvdogette
SW Louisiana
Posted: 05/25/08 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Question, where would be a good place to check if the slide room is level?
milzat
Louisiana
Posted: 05/26/08 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Set up the trailer on a hard surface, such as concrete.
Level the trailer.
Place a 4' level under the floor of the slide room, between the two slide mechanisms.
Adjust as needed.
Good luck,
Mike
* This post was edited 08/20/08 07:08pm by milzat *
Charlie D.
Gonzales, La.
Posted: 05/26/08 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Adjusting the slide so that the inner seal on the inside is better compressed will not solve a leak problem. The external seals on your camper are the ones that should prevent water penetration. Look closely a them to make sure that they are not deformed and are making good contact with your slide.
Enjoying Your Freedom?
Thank A Veteran
2007 Holiday Rambler 32SKT
2006 Chev LT D/A CC
rvdogette
SW Louisiana
Posted: 05/27/08 07:55am Link  |  Quote  |  Print  |  Notify Moderator
Thanks milzat!
Charlie, I have looked at the seals several times on the outside and they look perfect, no cracking and they are flush against the outside slide wall. I even went out and bought the 303 protectant to treat both of the seals. That's why I was so confused about what was going on when I realized that when the slide is out the inside right facia trim is not completely sealing like on the left side.
A can of vege's got caught between the slide and wall without me noticing at first and the force burst the can before I realized what was going on, what a mess. I believe that put the slide out of sinc(sp.)
Charlie D.
Gonzales, La.
Posted: 05/27/08 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Some slide outs have a rain gutter just above the slide out. There should be a sealant at the seal above this gutter. Make sure that the sealant is good and that there are no cracks. Cracks could allow water to get behind the gutter and penetrate the wall.
Good luck
rvdogette
SW Louisiana
Posted: 05/27/08 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, I will check that out. Learned something new today, I am going to be so smart when I grow up, hehe.
Love this forum
