RV.Net Open Roads Forum: Fifth-Wheels: Bed liner and 5th wheel Hitch???
 > Bed liner and 5th wheel Hitch???
racfan9
Springfield, Mo.
Posted: 05/25/08 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Can you mount a 5th wheel hitch in a bed that has a plastic bed liner in it?
Thanks, Racfan9
Dale M
Calgary
Posted: 05/25/08 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
Hi. Its Not a good idea, the liner will flatten out and you will have loose rails. Put the Hitch in first and cut out the liner to go around it if you want the liner.
Dale M
2006 GMC 2500HD D/A 4x4
2007 Wildcat 29RLBS
Hijacker 16k Slider
Prodigy Brake Control
Honda EU2000i Generator
BlackSilver
East of Heaven, North of Hell
Posted: 05/25/08 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
What Dale said!
DO NOT install a 5th wheel hitch over a plastic "drop-in" bedliner.
Hans, KØHB & Colleen, KØCKB
Master Chief Radioman, US Navy
'04 Prairie Schooner 34FBR Platinum XL Camping Trailer
'08 3500HD Silverado Big Dooley LTZ Go-power by Max & Allie
My rig (Click)
rray32539
Florida's Emerald Coast
Posted: 05/26/08 02:21am Link  |  Quote  |  Print  |  Notify Moderator
Not if you want to keep your fiver hitched up. The plastic prevents the hitch from being secured tightly to the bed of the truck. Eventually the hitch will loosen and the bolts will rip out of the bed. Then you will watch your fiver go into the ditch, or worse.
Lose the plastic bed liner. You can have a spray-in liner and make that work.
Richard L. Ray KI4PEQ
Laura L. Ray
Zoe Ray
2005 Ford F-250 "The Blue Beast" towing 1995 Jayco 277RB "Love Shack"
Home is where we park it.
PackerBacker
Montreal, Quebec,Canada
Posted: 05/26/08 03:26am Link  |  Quote  |  Print  |  Notify Moderator
Here's what Reese say about it;
Can I install over a bed liner?
Do not install mounting rails over plastic bed liners. Plastic bed liners must be cut out of the way. Base rails may be installed on spray in liner. Note: Consult installer for recommended curing time.
Eric
2009 Holiday Rambler Admiral 33SFS
Good Sam's - FQCC/Camping Quebec
My Photos
fuzzy194
R.I.
Posted: 05/26/08 04:58am Link  |  Quote  |  Print  |  Notify Moderator
Yes you can .I have done it two the last 3 trucks i have had.Never had a problem with any of them ,Pull a 40ft 5er all over this country.Take an cut out just were the rails go,then drill out your holds in bed.( cut out the hold rail not just were you will drill )
Lisa125
Northern CA
Posted: 05/26/08 07:56am Link  |  Quote  |  Print  |  Notify Moderator
No. The very experienced hitch guy we used said don't do it.
We got a spray in bed liner, then installed the hitch and it works great.
08 2500HD diesel/cc/4x4/sb/superglide w/superrails
08 Durango 325bh
1 22 month daughter
2 bratty border terriers Sam and Jenny
Hummer1
Vancouver Wa
Posted: 05/26/08 08:27am Link  |  Quote  |  Print  |  Notify Moderator
I did it for years without problems,when you tighten the hitch rails down it flattens the bedliner down as thin as a gasket.Never had the bolts get loose.I have herd it is illegal in Canada.
RCMAN46
NorthWest
Posted: 05/26/08 08:34am Link  |  Quote  |  Print  |  Notify Moderator
I would not do it. Most hitch manufactures advise against it. Just because a few have dodged the bullet does not mean it is wise. You know that 4 way stop at the end of your road. You probably could run the intersection without stopping for a couple years and never have a problem.
Sorry I did not notice that Fuzzy was cutting out for the rails. That would be OK but I noticed some others said it was OK to mount directly over the bed liner. That is not OK. I picked the wrong post to quote.
pennerk
Clovis CA
Posted: 05/26/08 09:13am Link  |  Quote  |  Print  |  Notify Moderator
With a Superglide with the removeable rails you can have a bedliner in your truck. The pins for mounting the superails into the bed of your truck come in different lengths depending on you application.
