RV.Net Open Roads Forum: Toy Haulers: Keystone Fuzion 362 Tires Issue
Search only in Toy Haulers
 > Keystone Fuzion 362 Tires Issue
matthewc66
San Diego
Posted: 05/26/08 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have an 07 Fuzion 362 with about 650 miles on it.
I had a blow out the other night and am concerned about the tires and wanted some advice.
They are basically new and there shouldn't be tire failure. Maybe I picked up a nail, not sure.
The tires are "Mission" TC 108 Radial/T 225/75R mounted on 15 inch rims. They are "Made in China".
I drive under my GVWR by about 600 pounds so I am not overweight and always stay at 55mph.
Do I have anything to worry about with these tires?
Has anyone else had issues with these tires?
Should I swap them all out?
Or is this just one puncture and I should mellow out?
Also, when I go to get new tires for the RV do I go to Camping World, a truck tire store or somewhere else?
Ran
Wisconsin
Posted: 05/26/08 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Matthew,
If you do a search under 'Mission Tires,' you'll find LOTS of negative comments and problems encountered by folks who have had them. Many folks have totally switched out wheels and tires and gone to 16" units with a load Range 'E' weight rating.
I have an '08 Raptor (same manufacturer as your Fusion), and I switched out my 15" load range 'D' Carlisle tires for 15" load Range 'E' Denmans. I only have about 2,000 miles on them, but they look great with no signs of abnormal wear.
cwill925
Murfreesboro TN
Posted: 05/26/08 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
I have an '08 Fuzion 362 with the same 15 inch Mission tires. To date I have about 3000 miles with no problems. I run up to 80 mph on the open road and have had it on some really rough roads also. I check the condition and pressure before each leg of a trip. I look for cuts and other signs of damage and deterioration. I run with 60 psi and check lug torque before hitting the road. With all the bad reports on the Mission tires, I guess I pay a more attention to them. The first sign of trouble, I'm switching brands.
'08 Fuzion 362
'02 F-350 7.3 PSD
4 motorcycles - 3 Harley's, 1 Honda
snohobro
wa
Posted: 05/26/08 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
they"re made in china!!! need i say more?
matthewc66
San Diego
Posted: 05/26/08 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
I think the Chinese excuse is hot air.
I use Maxxis tires on my atv's and they are considered the best their is. Their parent company is Cheng Shin.
I want to avoid dropping huge dollars on 6 new tires on everyone ranting over Chinese tires.
Let's not forget Firestone's issues with Ford a few years back.
I need solid advice because it will cost me a lot of money to replace all 6 at once.
sasha_j
Dumfries, Virginia
Posted: 05/27/08 11:46am Link  |  Quote  |  Print  |  Notify Moderator
I would check with Keystone to see if they have an upgrade path to 16" wheels
Our Web Site
05 Ford F350 SD 6.0 PSD CC LB 4x4 SRW Lariat, 11500 GVWR, Alum Ricksons, G124 265/70R/19.5/G tires, Airbags
05 Snowriver 8'10" Super Slide w/ 100 W Solar, All Weather, slides
07 Prolite 7.5x14 V Nose Aluminum Toy Trailer Mobile Garage
Mr BigBlock
Stoney Creek, Ontario
Posted: 05/27/08 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Fuzion 373 with 15 inch MIssion tires i now have over 12,000 miles on them and they r great no probs at all i check the tire pressure a couple times a day on a long road trip never even had to put air in them yet.
2008 Fuzion 373
2008 GMC 3500 Summit White CC Dually 4x4 Duramax SLE Sunroof DVD player 8'6" Arctic Plow 20 Drawtite 5th Wheel Hitch
1997 Seadoo GTX
1969 Dodge Charger R/T 440 Mag
2005 GMC 3500 SRW 4x4 Onyx Black
matthewc66
San Diego
Posted: 05/27/08 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
I am heading to the tire store tomorrow and see what they say also.
sasha_i, that is good advice.
I will call Keystone tomorrow and try and see what the rational is in upgrading and if there is a way for me to get there. Not going to hold my breath though.
pronstar
The LBC
Posted: 05/27/08 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
You check your tires hot?
2007 Dodge Ram 2500 CTD 4x4/QC/LB
2008 Stellar 23' Toy Hauler
08f450psd
Westminster, Maryland
Posted: 05/28/08 04:59am Link  |  Quote  |  Print  |  Notify Moderator
I was wondering the same thing. What good does it do to check tires hot ?
