RV.Net Open Roads Forum: Questions H20 heater 08 Jayco Jayflight G2 29BHS
 > Questions H20 heater 08 Jayco Jayflight G2 29BHS
dbcc186
Massachusetts
Posted: 05/26/08 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
I just took delivery of the trailer a few days ago and I have some questions about the water heater. It is an Atwood that has DSI and can run on both electric and gas.
1) When lighting it up at monitor panel by either electric or gas or both, is it all right for the switches to stay red? The directions are not the best.....
2) Should the switch lights go out after it has attained the correct temp?
3) Where is the temp setting? The directions are very vauge. I looked behind heater outside trailer and I can not find any dials or switch.
Thanks!
2002 Chevrolet 1500 4x4 Ext.Cab 5.3 3.73 rear
Putnam Class V XDR
Prodigy
2008 Jayco Jayflight G2 29BHS
MAXX AIR
Tornado
Reese Strait Line Dual Cam 1,200 lb Trunnion bars
rmw1990
East Central Georgia
Posted: 05/26/08 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
The switches on ours stay red when turned on. Sorry I can't help with the temp setting. I'd like to know the answer to this also.
2000 F250 4X4 CC 7.3PSD
07 Jayco Jayflight 28 RBS
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 05/26/08 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
It's OK for the lights to stay red, shows that everything is on and working. The temperature is preset at 120 degrees and not adjustable. So it's ultra easy for us mortal's to use! Also, you can shut down the gas part of the water heater ond=ce the water is hot, the electric rod will maintain the temperature. Switch the gas back on just prior to taking a shower to ensure you have enough hot water, tho! Again...nice trailer ya got there! Gotta love those Jayco's!
High Impact
Indiana
Posted: 05/26/08 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
We have the same camper and heater - we use electric only to maintain the temp but switch on the gas right before the daily shower routine and when originally warming up the cold water. The lights stay on when they are enabled and the water heater is non-adjustable.
Good luck!
07 Jayflight 29 BHS
07 Yukon XL 1/2 ton
DznyFan
Lorton, VA
Posted: 05/27/08 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
For whatever reason this topic confuses me. While my current TT isn't a Jayco, the first one was, I do have the Atwood Gas/Elec/DSI 6 gallon water. If I'm reading the manual correctly the light indicates either a non-ignition situation (no gas, no spark - page 4, line #5 under Electronic Ignition Maintenance) or thermal cutoff (excessive temp - page 4, line #5 under Electronic Ignition Operation). I can't remember if my light is on during normal use or not, I haven't used it for several months. The temp is factory set at 140 degrees and cannot be adjusted. It can be very, very H-O-T so be careful, it come on fast when you turn it on.
* This post was edited 05/27/08 12:57pm by DznyFan *
2006 Fleetwood Wilderness 3102BDS
2004 Excursion XLT 4x4 V10 4.30
Ride-Rite Air Bags | Air Lift SureSet
Hensley Arrow | Prodigy
Honda EU2000i Gennies
Garmin nĂ¼vi 350 | ScanGaugeII
_________________________________________
Me, the Wife & the Kid
Loopy
Western Pennsylvania
Posted: 05/27/08 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
DznyFan, he is talking about the switches themselves, not the little dot next to it.
To the OP, if the indicator in between the two switches remains on after turning the propane switch on, then you need to turn it off and wait a few minutes to try again. It didn't light.
Bryan , Jess, and our Parsons Russell Terrier, Melvin
1999 Chevrolet Tahoe 4D 4WD 5.7L 3.73" Rear End
Reese Strait-Line Dual Cam Weight Distribution Hitch
Tekonsha P3 Brake Controller
2008 Jayco Jay Flight G2 20BH and Mods
DznyFan
Lorton, VA
Posted: 05/28/08 07:04am Link  |  Quote  |  Print  |  Notify Moderator
That's what I was talking about, the rectangular red light between the two switches. I'm not sure what dot you're referring to. I believe you reiterated, briefly, what I said, a non-ignition situation. I guess I should have included "if the light doesn't go out after a short period" or "if the light comes on" but the directions make no mention of this aspect as well, I was taking the info from the manual. Like the OP said, the directions are not the best and this has, for whatever reason, always befuddled me. If I turn on the switch and I get hot water then all is good.
Loopy
Posted: 05/28/08 09:33am Link  |  Quote  |  Print  |  Notify Moderator
The OP is talking about the actual switch staying illuminated. You know, when you turn it on, the switch lights up. Yes, this is normal, it tells you that you have turned it on.
Again, to the OP, if you turn on the propane switch(which will be lit even if the propane doesn't light)and after about 30 secs. the little round indicator light next to the illuminated switch comes on, then your propane didn't light. In this case, turn off the illuminated propane switch, wait 30 secs and turn it back on.
Papasmurf10
Monrovia,MD USA
Posted: 05/28/08 11:32am Link  |  Quote  |  Print  |  Notify Moderator
I am not sure if mine is the same water heater but when the light on mine comes on it indicates the gas did not ignite. The best way to tell is turn off the electric, turn on the gas and if the light comes on wait 20 to 30 minutes. If you don't have hot water, the gas is not lighting. On mine and a friend of mines, I have to go through the re-ignite process about 4 to 6 times before it will stay on.
DznyFan
Lorton, VA
Posted: 05/28/08 11:52am Link  |  Quote  |  Print  |  Notify Moderator
Reading your post I'm thinking we have two different wall plates with the switches. Is your water heater an Atwood or a Suburban? On my wall plate used with the Atwood I have, left to right, the switch for the elec., the red light and the switch for the gas. I don't have the round indicator light like you mention (see below). I'm thinking, without actually trying it, that my switches/light funtion as described by Papasmurf10 but without the problem of staying lit. I cannot remember the red light being illuminated for the duration of my trips.
