RV.Net Open Roads Forum: What causes the black cloud of death? UPDATE 6/29
Search only in Tow Vehicles
 > What causes the black cloud of death? UPDATE 6/29
Maine-iacs
Maine
Posted: 05/27/08 05:47am Link  |  Quote  |  Print  |  Notify Moderator
I'm a complete novice in the diesel world. Bought our 04 this winter and just made the first long trip towing our 5th wheel. No problems encountered until about 5 miles from home. Got off the Interstate, fueled up and ran into Wally world for a few supplies. On leaving there was a slight uphill grade.
The truck had no power to speak of, stumbled a little (if it was a gasser I would say it was flooded) and was belching the most enormous black cloud of death you can imagine. I've seen freight trains run by with less smoke. After a half mile or so, everything was back to normal both uphill and down. Nothing lit up on the dash. I'm going to the dealer to have error codes checked but wonder if anyone has thoughts on what could have happened?
* This post was edited 06/29/08 05:11pm by Maine-iacs *
Maine-iacs from the Great State of Maine
2002 Holiday Rambler Presidential 30SCD 5th wheel
2004 F-350 Lariat X-Cab PSD FX4 longbed
RRUGG
Newaygo, MI,USA
Posted: 05/27/08 05:51am Link  |  Quote  |  Print  |  Notify Moderator
Might be a clogged fuel filter. Sounds like our truck did with the clogged filter.
RRUGG
2008 Dodge 2500 QC 4x4 SB Cummins 6 speed auto 3.73
1997 Holiday Rambler 29FK travel trailer
2006 Summit 22RB travel trailer
2003 Dodge Grand Caravan Sport
Bob & Grace professional retirees
Good Sam life members
Camped in 49 states. Missing Hawaii.
squeakkos
parker az
Posted: 05/27/08 06:10am Link  |  Quote  |  Print  |  Notify Moderator
check your air intake or the big hose off the turbo the sometimes pop off.
swebber
Brunswick , MD
Posted: 05/27/08 06:23am Link  |  Quote  |  Print  |  Notify Moderator
Ditto that !! But you did state that it was back to normal later on...I would also change the fuel filters if you have not already done so.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
squeakkos
parker az
Posted: 05/27/08 06:31am Link  |  Quote  |  Print  |  Notify Moderator
maybe you didn't let it cool down befor you shut it off at wal mart and the turbo got hung up?
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Posted: 05/27/08 06:32am Link  |  Quote  |  Print  |  Notify Moderator
Well lets see it was running fine before your fueled up and now it doesn’t, you might have got a load of bad fuel. If you didn’t add gas then you will need to get some Diesel Fuel Conditioner and Cetane Booster and change out the fuel filter maybe up to 3 times. This happened to me and the station did pick up the cost of the filters and I did the labor.
Don
* This post was edited 05/27/08 07:30am by Perrysburg Dodgeboy *
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
pics
rob85546
Hot arizona
Posted: 05/27/08 06:47am Link  |  Quote  |  Print  |  Notify Moderator
Went back to normal?? hum
Mine did that too on my psd..... ended up with a new EGR and Turbo??
2007 GMC DURAMAX,LBZ,4 by Crew, Allison
Magnaflow Turbo Back Exhaust
Predator Tuner
18by9 Helo's on BFG's
5year old boy
3 year old baby girl
Sea ray boat
Wilderness 5th wheel
SandRail
HD WideGlide
FORD Expediton
honda Eu3000
outdoorsman2007
In the Woods - Somewhere!
Posted: 05/27/08 06:59am Link  |  Quote  |  Print  |  Notify Moderator
First thing I would do is change the fuel filter. That is probably the problem. When the engine doesn't get the fuel pressure it's asking for (because of a dirty fuel filter) the computer puts the engine in safe mode. Once you turn the truck off and back on it will go away until the next time the pressure isn't reached. It will only get worse.
I keep a spare fuel filter and the tools needed to change it in the truck. Takes about 15 minutes.
gouldc
Edmonton, Alberta Canada
Posted: 05/27/08 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Could be the filters but it seems strange that it would be back to normal within half a mile. The black smoke is usually from over fueling. Could be an EGR that is starting to gum up. If you float over to t h edieselstop.com and search on sticking egr, you'll have ours of reading. Somewhere buried in the threads is a how-to on cleaning the egr. Unfortunately it's something that has to be done on a regular basis with the early 6.0Ls.
03' Lariat F350, 6.0L Short Box *SOLD*
04' Jayco Eagle 28FKS *SOLD*
08' FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
07' Keystone Raptor 3712TS PICTURES
Reese 18k Signature Series Hitch
Maine-iacs
Maine
Posted: 05/27/08 08:33am Link  |  Quote  |  Print  |  Notify Moderator
The diesel fuel was from a high volume truck stop, so I'm reasonably confident it's not bad fuel. (And no, it was not gasoline, but I do understand that it happens from time to time!)
I will change the 2 fuel filters as suggested.
I will read the threads on sticking EGR valves. Is the EGR valve a user replacement item?
