RV.Net Open Roads Forum: General RVing Issues: How to clean holding tank gauges
 > How to clean holding tank gauges
ampmsmokers
Kansas City Mo
Posted: 05/27/08 07:14am Link  |  Quote  |  Print  |  Notify Moderator
My black water tank always regesters 2/3s full. What is there to use on the market or home fix it that will clean the crud from the sensor?? Thanks in advance. Phil
skipm
Saint Helena Island, SC USA
Posted: 05/27/08 07:26am Link  |  Quote  |  Print  |  Notify Moderator
I personally haven't tried it but others have said to put 5 gallons or so of water in the tank and add a couple of bags of ice, then take the rig out for a trip down some windy roads so that the water has a chance to slosh around the inside of the tank. Between the water and the ice it is supposed to clean the probes. You may also try using one of the flushing things that goes down the toilet and try to direct the spray towards the sensors (you should be able to ID thier location by the wiring coming out of the tank) and maybe that will dislodge whatever is causing the false readings. Good luck.
JUrban
Delaware
Posted: 05/27/08 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Whatever you'll do will be a short term solution. You can either live with the problem or the continuous periodic cleaning, or spring for the outside mounted sensors such as are in the SeeLevel or Snake River Electronics (or others) systems. I've used Snake River and now have a SeeLevel and would recommend either.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
narcodog
Georgia
Posted: 05/27/08 08:44am Link  |  Quote  |  Print  |  Notify Moderator
I used the ice thing last year and my sensors are still ok.
stevenicoldeactivate
Hillsboro, Oregon
Posted: 05/27/08 08:46am Link  |  Quote  |  Print  |  Notify Moderator
...do a search on RV.net on the GEO method; it works for fixin' those gauges!
NORM WADDELL
PENSACOLA FL 32514
Posted: 05/27/08 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Several technicians have suggested
use of Pine Power, a 'PineSol'
type product sold in many stores.
L NORMAN WADDELL
30 FOOT ALLEGRO
SATURN TOAD
WIFE AND 2 DOGS SUGAR BEAR & COCO BEAR
AO_hitech
SF Bay Area
Posted: 05/27/08 09:00am Link  |  Quote  |  Print  |  Notify Moderator
I used the detergent and water softener from the GEO method and fixed gagues that hadn't worked correctly in 20 years. I use Happy camper in the black tank and the sensors arfe still working years later.
Carolina Cruiser
North Carolina
Posted: 05/27/08 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Happy camper will work to fix the gauges as well. Just follow the directions. They make a blaster product but we just tried the regualr happy camper and it fixed our gauges in both tanks. I would highly recommend a full hookup site to be at when fixing the problem.
bldrbuck
Boulder, Colorado
Posted: 05/27/08 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Try this product. It is the best I've found.
Unique M and M -- RV Digest-It
Good luck
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
mmckell
Central Valley, CA
Posted: 05/27/08 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
I had same 2/3rds full problem. Stopped at a CW and they recommended a granular (I think) product but I don't remember name. It was next to Aqua Chem products. I put it in, filled up (or nearly so) tank with water, let it sit overnight then drove it to agitate (or v.v.), then dumped it. Directions are on container. It worked like a charm.
