RV.Net Open Roads Forum: Class A Motorhomes: Lists, Good Ones
 > Lists, Good Ones
bustersbud
Based in Southern Ontario
Posted: 05/27/08 09:56am Link  |  Quote  |  Print  |  Notify Moderator
I searched lists and didn't find much of a selection. We are just getting ready to go back full timing after 6 years in a stick house and I would appreciate a good Checklist for leaving and travel with our Pusher and Toad.
Come on guys, lay em on me!
02 38' DutchStar, 02 Explorer Sport Trac 4x4, Remco Disconnect.
Ever Increasing Amounts of Useless Information
RV Questions
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 05/27/08 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Did you try the blue bar above, under the bold RV.NET is a RVing FAQ section, search for checkoff lists.
bustersbud
Posted: 05/27/08 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Hi Slate
Yes, I did check that out but I'm thinking there's better checklists out there. As the years go by, the memory seems to go bye bye. I need a great list.
admiral0647
Illinois
Posted: 05/27/08 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Once you have your list, you should consider what I do... (I got this idea from a hints book)
Put each task you need to accomplish on a clothes pin (I painted mine) and attach the clothes pins to your visor when you have completed your camp set-up. Then as you prepare to leave camp, remove the pins one at a time, calling out the task to your partner, to re-enforce its accomplishment.
I find this system very flexible and effective. The pins remain in the driver's line of sight until removed, and you clip up only those pins that are needed for the particular camp. You can also add and remove tasks easily.
I store the pins in a small zipper pouch, near the driver's seat.
Good luck and enjoy your RV.
Jim
2007 Damon Challanger 377c
2007 Toyota Yaris Dingy
2 Scotties
Jim's home page
Jonny 31C
Stevenson, Maryland
Posted: 05/27/08 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
PM me with your email address. I have a good checklist that we have been using for 4 years. It is excel spreadsheet so you can change stuff around to personalize it for your needs.
Jonny
Jonny
2005 Winnebago Voyage 33V
2008 Saturn Outlook Toad
Great Wife, 2 amazing kids, 2 beagles
doko
binghamton
Posted: 05/27/08 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
this is one i used to use.
happy trails
Departure Items In/Out
DUMP Black and Grey / back flush O
Outside water pump off O
Check ENGINE oil /coolant / washer fluid O
Check Generator oil & coolant O
Check tire pressure O
Awnings up and secured O
Doormat/ Mats away O
Stairsaver blocks away O
Clear exit path of debris/branches above O
Disconnect Fresh Water O
Disconnect TV cable & Phone lines O
Lock and secure almost all storage bays O
STATUS Black water (#1) I
STATUS Grey water (#2) I
STATUS Propane I
Lights off I
Raise window blinds I
Windows Closed I
Close/secure/check roof vents (2) I
Remove obstructions away from slides I
Make sure Captain chair out of the way I
Secure LR items / slide in / lock arms I
Secure BR items / slide in / lock arms I
Secure all Kitchen items / Refrigerator I
Secure microwave carousel I
Secure desk & telephone(s) I
Secure TV antenna I
Secure all roof vents I
Water heater OFF (gas & electric) I
Water pump Bath and Main OFF I
Comfort Control Thermostat OFF I
Secure Bathroom items / vanity closed I
Lock shower door I
Start Generator (if needed) I
Jacks UP I
Visually VERIFY that all jacks are UP O
Disconnect Shore Power / Lock bay O
Disconnect SEWER / Lock bay O
Secure all bikes after toad on O
Lock Main Door I
Start Engine / Stairs retract / verify I
Release Emergency Brake I
Detach Toad (see sheet 4) O
Check Transmission Fluid O
Leveling System ON / Hit Auto button I
Check Freezer Level I
UNLOCK Slideouts I
Deploy Slideouts I
Check vent(s) I
Shutdown generator (if on) I
Lock Steps down I
Propane tank valve ON O
Connect SHORE POWER O
Connect Fresh Water O
Connect SEWER O
Comfort Control Thermostat ON I
Water heater ON I
Mat out O
Deploy Awnings O
bustersbud
Posted: 05/28/08 11:36am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all. I appreciate your help.
Larry
Jim4455
Wherever I choose
Posted: 05/29/08 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
Admiral, I like your idea and plan to use it. Now if I can remember to do so.
1993 Winnebago Vectra 33' 454 Chevy
2002 Saturn LW200
Blue Ox hookup
urmine351
fort smith, arkansas
Posted: 05/29/08 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Mine only has one item
Remember to get DW before pulling out.
she will remind me of all the rest....and help me drive too, from the passenger seat....lol
1996 Safari Serengity, 3126 Cat,Allison 6 speed, 38' DPNS, 2005 Honda Element,vip tow brake. doran tire sensors, Magellan750Nav,
and 1 good looking wife, and missy and Alex(died 11-03-06) and AJ, born 09-06-06 my carins.
FMCA # F374886
bohemians4956
New Mexico
Posted: 05/29/08 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
Now Admiral, that is a pretty nifty idea. There's been countless times we've seen rigs going down the road with their crank-up antenna standing upright and just a flappin' in the wind or their steps still extended out. About a week ago I was in town and there was a fifth wheel going down the road and one of the cargo doors was open. Fortunately he was headed into Wally World so his pooch could, well, you know so I followed him in and gave him a heads up. Good idea you have there...thanks for sharing.... had to laugh at the next thread about "trying to remember to use the pins" though. see ya. C
 > Lists, Good Ones
