RV.Net Open Roads Forum: Tech Issues: Odd size Atwood drain plug
 > Odd size Atwood drain plug
cman12
Boise,ID
Posted: 05/27/08 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 1994 Atwood G6A-7 waterheater. I need to replace the drain plug that cracked. It is not the standard 1/2" (91857)drain plug that Atwood now uses. I contacted Atwood and they can' t find information for that far back, yet.
The original plug is slightly smaller than 1/2". Has anybody encountered this and what is the fix?
robatthelake
Vancouver Island
Posted: 05/27/08 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
Drive over to a plumbing supply shop and borrow a micrometer Tool to measure the Threads! Or Just try several Brass or Plastic plugs until You find the size that fits!
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
nbounder
Arizona mountains
Posted: 05/27/08 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
I'd do like Rob said, except I'd ask the plumber dude at the shop to supply you with the replacement. Any good plumber should be able to look at it once and know 'zactly what you need.
Joe
dougrainer
Carrolton
Posted: 05/27/08 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
In almost 30 years as a RV tech, I have NEVER seen a drain plug on an Atwood that does NOT use the 1/2 inch plug. I HAVE seen various modifications to install petcocks and such. I would bet the original plastic plug is either stripped out and you need to remove the plastic that is stuck on the inside threads OR someone has installed a insert that is slightly smaller and that is what you are seeing. Long shot is someone screwed up the original threads on the tank and have used some type of threaded insert that is smaller than the original 1/2 inch threads. Doug
cman12
Boise,ID
Posted: 05/27/08 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
This could be the case. Now I just need to find the replacement (didn't have time today).
1/2" plug vs my cracked original.
* This post was edited 05/27/08 09:53pm by cman12 *
SteveB
Rhode Island
Posted: 05/28/08 03:58am Link  |  Quote  |  Print  |  Notify Moderator
cdman,
I had a '94 Dutchman with an Atwood water heater and it used the standard 1/2" plug. Chances are that someone modified the original in some way as doug stated. The old plug looks like it might be a metric straight thread.
SteveB
'01 Dodge Ram 3500 CTD HO 6sp, Reese 15K Pro w/ Kwik Slide, Prodigy
'04 Jayco Jayflight 28.5RKS
robatthelake
Vancouver Island
Posted: 05/28/08 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
Now that I have seen the plug , I'm thinking that You will need to run a 1/2 " Tap into the Tank to correct the Cross threading that appears to have caused the original plug to distort! Be Very careful and That Should fix the problem!
cman12
Boise,ID
Posted: 05/28/08 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
I took the plug to hydraulic supply company. They have both Imperial and Metric plugs. They measured the plug(diameter,threads etc) and didn't find anything that would fit.
Rob, The poor picture doesn't really help but there is no visable cross-threading on the plug. But retapping might be my only option without replacing the tank.
I ran across one other person that has this odd size plug and needs a new one too.
Troubleshooter
Anchorage, AK
Posted: 05/28/08 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
I have run across some Nylon plugs that have a short taper on them, and some that have a long taper.
You might try your local ACE, Home Depot, or the like, and see if you can locate a 1/2" Nylon plug made by Watts, P/N PL-1189.
I use them in our Atwood water heater, and they seem to work for us.
Only One Old Fellow's Opinion
Bill
2002 Discovery 3126E CAT
2004 Saturn VUE
Mountain Master Tow Brake
SteveB
Rhode Island
Posted: 05/28/08 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
cdman,
Could it be a screw thread? 9/16-18; 9/16-24; 5/8-18 UNF?
Steve
