RV.Net Open Roads Forum: Fifth-Wheels: Electric Landing Gear
 > Electric Landing Gear
JFJ
TN
Posted: 05/27/08 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
I just purchased my first 5th Wheel (used). While lowering my landing gear for my first trip, the motor stopped working. My wife initially had lowered the unit. When she realized she needed to go the other way, the motor would not work. It made no sound. I had to use the manual procedure to raise and lower the landing gear. It had worked perfectly prior to this and never gave any sign of problems. I checked all my fuses and none were bad. Has anyone ever experienced this before?
2007 Dodge Megacab 2500 4X4 SRW
6.7 Cummins w/6 Speed Auto
2005 Raptor 3612ds
Pacbrake Air Bags
Prodigy Brake Controller
Pullrite Superglide 24K
Phils
Paradise, CA
Posted: 05/27/08 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
Both fivers I've owned had a separate inline fuse in the wiring for the leg motor, not using any of the fuses in the panel. Did you find one there too and it's good?
Phil
'03 F250 deezle and '01 Komfort 27FS
Off the grid and outta sight at home
Go camping to have neighbors and amenities
JFJ
TN
Posted: 05/27/08 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
I took a brief look and did not see any. I need to take a close look? Where should I start?
USAFBILL
Alabama
Posted: 05/27/08 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Battery fully charged?
PaulandTammy
Elk Creek, Ky
Posted: 05/27/08 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Look close to the battery. Had the same thing happen to me with my first fiver, I found the fuse going to positive side of the battery about 12 inches from the positive post on the hot wire going to the gear motor. I would think it would be somewhere between the battery and the motor. Good luck
PaulandTammy
2006 D3500 4x4 Cummins 6 spd DRW
2009 Cardinal 362 BHLE
dbbls
Missouri
Posted: 05/27/08 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is a circuit breaker close to the battery. Doesn't really look like a circuit breaker but it has a large wire from the battery and another going to the motor. There is a button on the back to reset.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
thecaptain
Belleville,Mi.48111 USA
Posted: 05/28/08 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Test the switch some times these go bad also.
Ken/Ellen(RET)
2000 F250 Superduty
7.3psd/Banksbrake/Smartlock/Trans command/3.73gear/Edge EZ module
2002/29ft-Terry 5er:
Take life one day at a time.
BruceStarkey
Ontario, Canada
Posted: 05/28/08 08:00am Link  |  Quote  |  Print  |  Notify Moderator
dbbls has described the later/newer "most common install", a small aluminum breaker fastened to a bulkhead somewhere close to the batteries. It resembles the old headlight breakers of pre-computer cars. It may have a small round black plastic button you can push in to reset. The inline fuse holders are still in use also.
Today is just the tomorrow you worried about yesterday!
'04' International 4400 LoPro 310Hp/950FtLbs 10Spd Harley/RV Toter
'05' Mobile Suites 38RL3
'01' Harley Ultra in the bike barn.
captain037
Montgomery, AL
Posted: 05/28/08 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Mine has an inline 30 amp fuse in the battery compartment.
red_neck_camper
Stafford, VA., USA
Posted: 05/28/08 10:17am Link  |  Quote  |  Print  |  Notify Moderator
One other thing for JFJ -- if you find it is a blown fuse. When changing directions with the switch, make sure you let the motor stop before switching to the other direction. If you switch too fast, this will frequently blow the fuse.
Ken
2007 FORD F-350 4WD SC Longbed, 6.0L Powerstroke, Reese Signature Series 18K hitch.
2007 Keystone Montana Mountaineer 342PHT
