RV.Net Open Roads Forum: Hybrid Travel Trailers: Bad thing happened.
Open Roads Forum  >  Hybrid Travel Trailers
 > Bad thing happened.
Chuck_S
Broadview Hts, OH, USA
Posted: 05/29/08 05:02am Link  |  Quote  |  Print  |  Notify Moderator
The smoke came from somewhere!
I'd take his offer to have the local RV shop test this to establish at least an implied warranty. If you miss something and sign off that it's all OK you may have undiscovered problems down the road (literally and figuratively).
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
ShapeShifter
Buffalo, NY
Posted: 05/29/08 05:22am Link  |  Quote  |  Print  |  Notify Moderator
I'm sorry to hear of your issues. But it's good to see that the contractor is taking responsibility without balking.
-- Chuck
I'll second that: get it professionally checked out.
No disrespect intended, but if you had to originally ask what to check out, then you aren't really qualified to check it out. Things may work now, but could be stressed or damaged to the point where they will stop working in the future (probabaly right after you sign off and release the contractor.)
Appliances or wiring could have damaged insulation or components. When they fail it will probably just stop working, or it could result in a short that causes a dangerous condition or fire. Granted, that's the worst case, and you probably don't have any serious issues, but the prudent thing is to thoroughly check it out. This includes opening up the breaker box and keyjunction and outlet boxes and inspecting the wiring and connections.
Like Chuck said, the smoke came from somewhere!
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
AutoEngMike
Erie, PA
Posted: 05/29/08 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Most likely the smoke may have been wire insulation melting. In that case the breakers may have protected your equipment and everything might work but you still have a potential fire issue when your wires shift and then short where the insulation melted. All wiring, appliances, etc. should be checked. It appears your 12VDC equipment is OK and the only thing you should be concerned with is the converter and other 110VAC equipment/wiring as far as testing goes.
2003 Dodge Ram 1500 Quad, 4X4, 5.7L Hemi, 3:55 gears
2005 Honda PilotEX (wife's)
2006 Rockwood Roo 23SS, 6500lb GVWR, Prodigy Brake Controller, and Equalizer 1K WDH
http://community.webshots.com/user/AutoEngMike
BarneyS
S.E. Lower Michigan
Posted: 05/29/08 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
Same thing happened to me a few years back on my previous trailer. It fried my converter, microwave, and shore cord. Refrigerator was ok. My television was not plugged in at the time or it may have gone also. My advice would be to take him up on his offer to have a dealer fix it. Too much at stake to trust your inspection on this.
Barney
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the new RV.net Blogs!
Visit our website here
hotbyte
Barnesville GA
Posted: 05/29/08 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
One thought is when wiring insulation overheats like that it often gets hard and brittle. It might seem fine now but after bouncing down road under tow it might crack and short out. Check all the wiring for discolored and/or hardened insulation and have it replaced.
Our Web Albums
For pulling...2005 Chevy 2500HD LT D/A and 1998 Dodge Durango SLT 5.2L
To be pulled...2002 Glastron GX205 and 2005 Pilgrim 276BH-5SS 5'er
splegge
St. Louis
Posted: 05/29/08 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
When you settle you may want to get in writing that contractor will cover any repair from electrical failure for a year period. Just because it does'w work know, doesn't mean it is not damaged.
Also a sugre protectors runs about $100 plus 10-20 for a lock up unit and lock....
2003 Aerolite C236 Cub Hybrid
2006 Chevy 2500 Suburban 6.0L
htowners
Quarryville, PA
Posted: 05/29/08 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
You need to get this checked thoroughly.
While the 12V is isolated via the converter (transformer) in order to get 240V then what should have been either the neutral or ground got energized with the other 120V leg from your panel. Usually these poles are not fused, and at least the ground could quite possible be bonded to between both sides, therefore the 12V is not truely isolated, if it was the ground that was energized.
As others said, heat makes wire, and other components brittle, and while everything seems fine now, a few years and many miles, might cause future problems.
Today is the only day that you can use to take steps towards the great future you see. Yesterday is gone forever and tomorrow never comes, it’s always today.
2007 Dodge RAM
2007 Jayco 26L
1 DW
2 DS
1 Sheena the wonder dog
Padlin
W. Ma.
Posted: 05/30/08 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
From what I've seen of RV dealers service techs, they aren't exactly electrical engineers. I'd suggest you have a good local dealer go thru it at the contractors expense of course, then if you know anyone in electronics have them poke around checking for fried wires and such as mentioned above. To open the converter and look around is pretty easy, I'd think if you had damage you will at least see something there.
Bob & Deb
W Ma.
04 GMC 1500 4X4, 5.3L
06 Starcraft 18SB
Gaffer222
Northwestern CT
Posted: 05/30/08 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
I would look for an on site RV tech as they seem to have more knowledge and better work ethic than some of the RV dealer in house techs.
2004 Ford Explorer - V6 w/Tow package
Equalizer & Prodigy
2005 EZ190 Keystone Zeppelin HTT
DW, DD Circa 2002, DD Circa 2005
My Webshots
maddog348
Bakersfield,CA
Posted: 05/30/08 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
Similar incident several years back - out of state friends RV elec post - my ClassC. Plugged her in 3-4 sec heard LOUD clicking - v.meter swinging wildly -pulled plug -- only blew microwave. Said parents used plug-in all the time -- never knew just what went wrong. Warr replace microwave - just cooked on stove rest of trip. Felt LUCKY that was all that happened. Got a 'SurgeGuard' & plug it in first to any 'unknown' elec supply.
