RV.Net Open Roads Forum: Travel Trailers: Caulking ABS tub surround
 > Caulking ABS tub surround
dbcc186
Massachusetts
Posted: 05/27/08 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have an 08 Jayco Jayflight G2 29BHS. In the tub wall enclosure there is a gap at top by wall and at bottom where enclosure meets tub. I am worried about water getting behind wall and causing damage, mold etc. Why wasn't this caulked at factory? Should I caulk both of these seams? If so, what type of cauling? Thanks.
2002 Chevrolet 1500 4x4 Ext.Cab 5.3 3.73 rear
Putnam Class V XDR
Prodigy
2008 Jayco Jayflight G2 29BHS
MAXX AIR
Tornado
Reese Strait Line Dual Cam 1,200 lb Trunnion bars
You can't take the Fisherman out of this Camper
Ontario, Canada
Posted: 05/27/08 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
No. It is that way by design. If you caulk it you take the chance of trapping moisture... condensation, etc. behind it. It will be fine the way it is... unless you spill/splash water down the wall at the top.
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: FINALLY... 2002 Cougar 276EFS; 2002 GMC 2500HD Ext Cab 4x4; (Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
swebber
Brunswick , MD
The top should be sealed with an adhesive from the factory but in the heat of the summer ours let's loose and I have to press it back. As for the bottom, it is not sealed as it allows condensation to drain. There is a lip that runs up an inch or two that prevents water from getting back there.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
browns329
New Jersey
Posted: 05/27/08 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
I was wondering the same thing about our new Jayco. I saw a thread here before, where most folks suggested that it is fine as-is. I have not caulked mine.
2003 GMC Yukon XL 2500 (3/4 ton), SLT, 4x4, 8.1L, Autoride, 4.10 gears
Putnam XDR, Equalizer 1400#, Tekonsha P3
2008 Jayco Eagle 314BHDS (Bunk house double slide)
Me, DW, 2 DD, lots of pets
dbcc186
Massachusetts
Posted: 05/27/08 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
I tried pressing it back in place too and it won't stick.
twinsmom04
BC Canada
Posted: 05/27/08 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
really glad to come across this thread... was wondering about it too.
TV - 2007 Silverado Crew cab shortbox with 5.3l engine
TT - 2007 28BHS Passport
campers include me and my 4 year old twin boys and occasionally DH
jay2003
San Joaquin Valley, California
Posted: 05/27/08 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
The other problem with caulking is that depending on the temp inside the trailer you may find that the caulk won't stay sealed. If you've every noticed the ABS tightens and loosens depending on the temp. Don't try and tack it down anymore than what the factory has already done or you might find it damaging itself when it tightens up again.
05 Toyota Tacoma DC 4x4 SB Off-Road Package w/Tow 128" WB
2005 KZ Jag 24JB*Newer Model Floorplans Slightly Different
Prodigy Brake, WD hitch, friction sway
Garmin GPSMAP 60CSx
Honda EU2000i Generator
Me.. the wife, the 5 year old, and the 2 year old
Gosple
Henderson NC
Posted: 06/17/08 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 08 jayco as well. Left it with my dealer for ten days and he did not fix the problem He said this gap at the top was normal and he could not fix it.Also the plastic rivets are not tight to the wall either. I called Jayco on 6/17/08 and was advised this was not normal and I am waiting to see what they will do about it. I will post when I get a answer from Jayco
Jeremy626
IL
Posted: 06/17/08 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
oops, I caulked the top and bottom before the tub/shower was ever used. I guess if it's sealed from the get go, there shouldn't be any moisture back there.
Jeremy
Rig: 2002 Palomino Stampede S21-SDSL
TV: 2007 Chevy Trailblazer LT 5.3L V8, 3.73
Equal-i-zer, Prodigy BC, Navigon 2100 Max GPS
2008 Trips We've Taken
Gosple
Henderson NC
Posted: 06/17/08 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
I was just wondering if anybody knows what the name of the manufacture of the tub surround in a jayco travel trailer. Would be interesting to know how they recommend to install the surround. If it was installed correctly it should not come off so easy.
