RV.Net Open Roads Forum: Beginning RVing: Overfilling fresh water tank
 > Overfilling fresh water tank
savageflip
Seattle
Posted: 05/27/08 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
Super noob question:
Is there such a thing? I have been filling the fresh water tank until I see it spew out of non pressurized filler (not the city water connection) on the side of the trailer. But....I started to wonder if I that is the right way of doing this. I have noticed some moisture around the "bladder" on the floor of the trailer. Not a "significant" amount of moisture. But...any moisture on the floor of trailer does catch my attention.
Thoughts?
Quick trip
Cerritos, Ca.
Posted: 05/27/08 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
I usually never fill the fresh water tank full, but I do the same as you when I do.
It's easier than going inside to check the gauge every few minutes.
You might want to check the fittings from the filler to the tank and make sure they are tight, but don't over tighten!
I have never found water anywhere around the tank.
Good Luck & Drive Safe!
Chief45
Porterville, Calif.
Posted: 05/27/08 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
On some, when you allow it to overflow it will create a vacum and drain a portion of the tank.
ed6713
FL
Posted: 05/27/08 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
I fill it like you do. Until it overflows and gets my shirt wet.
The moisture is probably condensation. Cool(water) in contact with warm moist air. Just like the condensation that forms on your car windows.
rockhillmanor
On the Road
Posted: 05/28/08 05:36am Link  |  Quote  |  Print  |  Notify Moderator
That's what I like about my MH, it has a small bay door in the back that gives access to the water pump and a nice view of the water tank.
So to conserve on weight I can fill it just half way and can watch while I am filling it.
31 ft Four Winds
Chevy Tracker 4x4 BlueOx Aventa LX
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
ramzfam
Appomattox, Va
Posted: 05/28/08 05:54am Link  |  Quote  |  Print  |  Notify Moderator
My water fill area has a vent from the tank that is right next to the inlet. As you fill the tank the vent makes a gurgling noise. When the noise stops the water level is above the vent at the tank which means the tank is full and it's time to cut the water off. I don't know where the vent is on other rigs but there has to be one somewhere.
Have RV....Will Travel
2007 Forest River Sunseeker 2860 LTD
2000 Jeep Wrangler Sahara
FOREVER FREE
Manchester, TN
Posted: 05/28/08 05:59am Link  |  Quote  |  Print  |  Notify Moderator
I fill ours until the water comes out the vent hole. Never had a problem.
"BIG BOB" & DIANE:
Big Mac & Sarah (Retired Greyhounds)
2005 Prowler Regal AX6 365BSQS
2005 F-350 Lariat Crew Cab 4x4, DRW, 8'bed, 6.0 P/S Diesel,
Veterans, the reason we will always be "FOREVER FREE".
SUPPORT OUR TROOPS
Patty98311
Arkansas
Posted: 05/28/08 07:14am Link  |  Quote  |  Print  |  Notify Moderator
Ditto
savageflip
Seattle
Posted: 05/28/08 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Cool....thanks for the input.
hotpepperkid
Chino Hills CA
Posted: 05/28/08 10:18am Link  |  Quote  |  Print  |  Notify Moderator
Patty98311 wrote:
Ditto
me to
2000 Ford F-350 SRW 4X4 PSD 28' Prowler 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
