Squealers
NW Arkansas
Like others have stated....try the dash first. I have had satellite radio since its inception, and had run through 3 antennas mounting them on the tops of my vehicles. The vibration from the wind eventually loosened the connection wire to the antenna.
I now place the antennas on all my vehicles that do not have factory antennas on the dash (including the MH) and it works perfectly, plus, no more worn out antennas.
1999 Sea Breeze 33'
2002 PT Cruiser Toad
2006 Goldwing MotorTrike-Bushtec Trailer
& Other toys my wife finds amusing.
Patriot Guard Rider---Serving Those Who Served.
USAF Veteran 1975-1981 ATC-Giant Talk
Go Hogs!
OBie One
Louisville, Kentucky
We do what bfast does... we use the "home" kit for the myfi and put the black square antenta up on the dash board torward the center. We do not "open" the black the antena as it seems to receive better in the flat or folder position. The antena cord runs back to the docking station which I have a cig lighter power cord plugged into the dash aux power outlet. Then we transmit the signal via the FM setting ont he myfi unit. Works great and no permanent mounting.
dontay
Mims, Florida
james0930,
If your coach came with Sirius it probably has a roof antenna on or just behind the front cap. The Sirius antenna it will work with XM once you get the cable connector to match. That is what I did on my Tiffin which came with Sirius.
ISO9000 Certified Retiree
Mission Statement: ZZZzzzzzzzzz....
2006 Allegro Bay 34XB with Freightliner FRED chassis, 2000 Jeep Cherokee 4x4
http://community.webshots.com/user/longf450
frankandvicki
Niwot,CO
My coach came with Sirius like yours and I installed a dash mount for my portable XM. Used the antennae that came with the MH attached directly to the XM radio dash mount. I did not need a special adapter/connector as dontay mentioned. Should work for you.
Frank O.
Frank and Vicki
Niwot, CO
2006 Itasca Sunrise 35A
States visited/camped in, not just driven through.
chuckster11
Idaho
I had my XM installed in dash and the antenna is a wire that the installer simply ran up to the cabinet above the dash and left in amongst the other television and media cables that are there. It has been generally ok but this winter we experienced some patchy reception and I decided to route the wire under the insulation on the inside of the front cap. I'm not sure it is an improvement but we haven't had the fade in fade out problem as before. Overall we have had pretty good service from XM across country--very few blackouts. Still don't care for all the commercials on the "commercial free" XM service!!!!
TB1
Louisville, KY
I have XM and I mounted the antenna in the cabinet above the drivers position. It has metal shelves and I stuck it on the top one about 10" from the roof line. Ran the wire down the "A" post. Works better there than on the dash.
Tom & Sue
2000 HD Dyna Wide Glide
2002 Jeep Liberty toad
146.52
ctaurie1
Have an XMRoady and mounted the antenna from the Home kit behind cabinet above windshield under front cap. Even going through the fiberglass cap, it works great.
2006 National Surfside 34D
Ford V10
Saturn SW2 - Toad
subtroll
Hayes, VA
I just installed a Sirus system (think it is the same antenna). I first tried it on the dash by the windshield next to my Delorme earthmate GPS antenna. It worked OK but was probably better in some directions than others.
Now I placed the antenna just under the bare fiberglass roof inside an access above the drivers seat. Made a small bracket to hold it. Works great. When I asked the same question a few weeks ago (technology corner) several indicated they had good success inside. My original plan was to glue it to the roof, but the connector requires a big hole to get the cable inside.
2004 National Tropi-cal Sterling 396
2003 Jeep Liberty
03FatBoy
Topeka, Ks.
Put our antenna on the roof. I mounted a galvanized plate on the roof using roof sealant and routed the cable through one of the existing penetrations and resealed that penetration with sealant. I wanted to use stainless steel, but couldn't get a cheap piece that had magnetic properties for the magnetic mount to hold to. We have always had great reception with our set up.
Melissa & Steve (MNC USNR retired)
FMCA F335327, GS
'05 HR Ambassador 36PDD, Mitsubishi Ecplise Toad
8.3L Cummins w/ 6sp Allison
Under 2 and counting!
2cyber71
Pennsylvania
My MH came with a Siruis Radio and the antenna was installed by the factory on the roof just above the driver....very nice...all sealed and works like a charm....I'd find a way to follow the radio antenna and bring to the roof too
2007 Itasca Ellipse 40FD
Lucy 3 yr old Lakeland Terrier, in AKC Agility Training
Campground Videos
Lucy gets an Agility Ribbon, 2nd place AKC Trial, Finger Lakes Kennel Club
