RV.Net Open Roads Forum: Hybrid Travel Trailers: could you jog my memory?
Open Roads Forum  >  Hybrid Travel Trailers
 > could you jog my memory?
kellem
shenandoah valley
Posted: 05/28/08 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Coming home from a long wk-end of camping i noticed the driver,s side front tire of our Antigua would skid slightly when coming to a stop.
I first want to adjust the brake out slightly to see if this will help as i already tried adjusting the controller.
Do i rotate the adjuster up or down to back out the brake,i'm going to try one click at a time.
Thanks
tom_kat
way upstate new york/lake george area
Posted: 05/28/08 07:51am Link  |  Quote  |  Print  |  Notify Moderator
jack up each wheel to adjust the brakes evenly,check the wireing and magnets to to sure there all working.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
rvsatek
AZ, USA
Posted: 05/28/08 07:56am Link  |  Quote  |  Print  |  Notify Moderator
Down on the end of the adjusting tool will tighten the brake shoes.
Larry
1994 Ford F250/7.5L/410 gears
2001 Keystone Sprinter 276RLS 14' slide
kellem
shenandoah valley
Posted: 05/28/08 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Thanks,
I already drew them tight then backed them off 6 clicks earlier this year was looking for a quick fix.
Chuck&Gail
In the Colorado Mountains
Posted: 05/28/08 11:23am Link  |  Quote  |  Print  |  Notify Moderator
note you might be running too much tire pressure for your load also. our little trailer does that if tires have too much pressure. note DO NOT run lower pressure unless you have really weighed your fully loaded rig, and can use manufacturers tire tables.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
Drippin
Dripping Springs, TX
Posted: 05/28/08 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
What brake controller do you have?
A man, his wife, a son and Cody the Goldendoodle.
2008 Laredo 284BHS, 2001 Chevy Sliverado 2500HD 4X4 4.10, Equal-i-zer, Primus, Subaru RG4300iS
kellem
shenandoah valley
Posted: 05/28/08 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
Its a compact Reese Brakemen.
Chuck&Gail
Posted: 05/28/08 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Reese Brakeman is a timer based unit. IMO save up for a Prodigy.
