RV.Net Open Roads Forum: Second trip camper flooded!!! Roo 23SS and mystery drain.
Open Roads Forum  >  Hybrid Travel Trailers
 > Second trip camper flooded!!! Roo 23SS and mystery drain.
funkoptimus
Rochester, MN
Posted: 05/29/08 10:59am Link  |  Quote  |  Print  |  Notify Moderator
It would make sense but there is no valve to turn on or off.
Wonder if this is just on the newer ROO's or on the 2007 or later.
Jamie(the Funkster), Amanda, DD, and Mojo the camp' hound.
SLSAntigua
Pennsylvania
Posted: 05/29/08 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure about the Roos so please bare with me. What does the hose look like? Does it have an end. I would check the refrigerator vent on the Outside of the unit. there is a refrigerator condensation tube that is supposed to be sticking out of the vents. Like I said this might be different on the Roos. It is usually a white coiled tube with flat end that prevents things from going inside. if this tube is on the inside and just leaking inside as opposed to the outside then that could create problems later on.
Good Luck!
Steve
Steve, DW, 2 DDs
2006 Starcraft Antigua 215SSO
2008 GMC Envoy SLT
Voyager Brake, Reese WDH and sway control
funkoptimus
Rochester, MN
Posted: 05/29/08 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Good Luck!
Steve
Thanx for the reply Steve.
The fridge is on the opposite side of the HTT and drains in the normal fashion thru the access panel at the back of the fridge.
The hose being discussed looks like a rubber type that is smaller than a garden hose. Maybe half its size but similar material. It is almost right below the edge of the shower pan or bathroom sink. tonight or tommorow I will take a picture after Ifigure out how to post it!!
funkoptimus
Rochester, MN
Posted: 05/30/08 09:19am Link  |  Quote  |  Print  |  Notify Moderator
So is their a way to dry it out? Or not worry? Seems like most of it ran out of the corners pretty easy. But I know water got in under the toilet and the shower pan. To get under the shower I will to take off the whole surround I think.
mwebber78
New England
Posted: 05/30/08 09:59am Link  |  Quote  |  Print  |  Notify Moderator
It depends on how far they wrap the lino. under the sides and stapled it. I saw how Jayco's are made and on the laminate floor the lino. wraps nearly to the poly underwrap, so I'd say if the ROO is the same you may be OK.
However, since water does wick if the sides of the floor were not covered they have probably taken in some water. Also, the poly under wrap DOES hold in water.
Would I be concerned about the long term affects of trapped moisture? YES- I have read many floor rot stories where water was trapped under the poly layer.
Michael
2 DD's and my DW
6 Acre's of Maine
2009 Crossroads Cruiser CF31SB
2008 Chevy 2500HD Ext. Cab LT 4X4
Champion lil' yellow Chinese genset, 4000W
Camping Pictures
AutoEngMike
Erie, PA
Posted: 05/30/08 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
funkoptimus wrote:
...Another strange thing I noticed is a hose that is about 3 inches long that is sticking out from the bottom of the HTT it is between the wheels and the gray and black dump valves. Water was dripping from this after the flood. Looks to be some kind of drain. Anyone else have this or know what it is for??
I haven't looked in my 23ss but I think that drain is for the two sides of the slideout. I think it catches any moisture wiped off when pulling in the slide. If you look under the couch you might see the one on the front. I'll look this evening to see if I'm right.
Mike
2003 Dodge Ram 1500 Quad, 4X4, 5.7L Hemi, 3:55 gears
2005 Honda PilotEX (wife's)
2006 Rockwood Roo 23SS, 6500lb GVWR, Prodigy Brake Controller, and Equalizer 1K WDH
http://community.webshots.com/user/AutoEngMike
Chuck_S
Broadview Hts, OH, USA
Posted: 05/30/08 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
There are a pair if small hoses on the 23SS to drain the runoff from the slide as it's squeegied off on retraction. You can see the front collection pan and hose just by looking under the sofa, and the rear one when the slide is in if you look in the now open area behind the oven from the bathroom door area.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
funkoptimus
Rochester, MN
Posted: 05/30/08 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
-- Chuck
AH HA!! Makes sense!! Good too know!!
funkoptimus
Rochester, MN
Posted: 05/30/08 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
So what to do?? I feel strange gutting out a brand new HTT's bathroom to see. Would running a dehumidifier work?? Or any other ideas?
camperforlife
Richmond IN
Posted: 05/30/08 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
I think you have a lot to be concerned with.
My '03 Antiqua, when new, flooded first trip out because they left out part of the shower drain. I wanted Starcrft to buy it back and they assured me that they dried it out and not to worry. I asked and received a lifetime delamination warranty. Well, I noticed on a side wall this spring right where all the water ran out that it is starting to delaminate. I guess I'll see how good their word is.
2004 GMC Sierra 5.3, 3.73
2003 Antiqua 195CK SOLD and shopping for a replacement.
