rdpatt3
Alabama
The last couple of trips when I was sliding the slides in or out they would stop (mid travel,no noise or anything) then let up on the switch , re-apply the switch and it would work fine. Anyone ever seen this. Thanks in advance !
2006 Keystone Raptor 3612ds
2005 GMC Sierra 2500 Duramax
2000 Road King Classic HD
A Wife that will ride with me anywhere.
5O'clock
Northern California
I have had the same issue with my '08. Have yet to find the issue though.
01 Dodge Ram 2500 4x4 CTD, Edge EZ, BD TC/VB Exhaust Brake, Autoloc,Pressureloc
08 Raptor 3612DS, Pullrite SuperGlide
05 Polaris Predator 500
85 Harley FXST
"too many weekends.. Not enough beer"
markie mark
So Cal
Happened last year to our '06
Dealer adjusted
Works great ever since
06 F350 PSD CC FX4
06 Raptor 3612
05 CRF150, 02 KX85, 05 CRF70
01 KTM50, 05 PW50
06 Rhino 660
Member CORVA, AMA, ASA, BlueRibbon Coalition, AAPL
gouldc
Edmonton, Alberta Canada
Hydraulic fluid level's good? Battery? Have a look at the track when it pauses to see if there's a defect in the teeth at that location.
03' Lariat F350, 6.0L Short Box *SOLD*
04' Jayco Eagle 28FKS *SOLD*
08' FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
07' Keystone Raptor 3712TS PICTURES
Reese 18k Signature Series Hitch
kennydpc
colorado
change circut breaker from thirty to fifty amp promblem solved Idid it on my 05 3612
2005 ford f-350 ps cc lb 4x4 sw
2005 keystone raptor 3612 ds
2001 honda 350 rancher 4x4 (leslies)
2004 honda 450 foreman 4x4 (mine)1992 honda 300 4trax (ol plow rig)
1998 harley fatboy (ours)
wife (Leslie) 2 pugs (paul & ruby)
wild bill
Mira Loma, Ca. USA
The right answer was from kennydpc......change the circuit breaker to slightly larger and it will work fine!
05 Dodge 3500 Q-Cab,GearVendor 8 Sp,PacBrake,Banks intercooler & intake,TST R49,Transferflow 70 tank,TrailerSaver Hitch,05 Raptor 3612,Second AC, solar 6 battery sys Xantrex 3000,Sand Rail 02 Nightrain,ST4s KLR650,ll00RT,AOPA BMWMOA,EAA,HOG,TDR,NRA,FCSA
WhitehouseLV
Formerly Las Vegas, Now Big Sky State - Montana
wild bill wrote: The right answer was from kennydpc......change the circuit breaker to slightly larger and it will work fine!
yep, wild bill helped me with this same issue. Works fine now.
Traveling Whitehouse
2006 Keystone Raptor 3612DS
2004 Chevrolet Silverado 3500 CC LB DRW Duramax LLY 4x4
Reese 20K Hitch
Prodigy Brake Control
2007 Honda Rincon & 2000 Honda Rancher
gouldc
Changing over to a larger circuit breaker would require that the unit be connected to shore power right? Not always an option.
paul turner
Bakersfield
gouldc wrote: Changing over to a larger circuit breaker would require that the unit be connected to shore power right? Not always an option.
Its a 12vdc circuit. Batteries supply the juice.
paul
edited 05/29/08 07:41am by paul turner *
rdpatt3
Alabama
Thanks everybody, I'll change that breaker. Thanks again !!!
