RV.Net Open Roads Forum: Class A Motorhomes: Toilet bowl won't hold water.
 > Toilet bowl won't hold water.
kplender
Denver
Posted: 05/28/08 11:37am Link  |  Quote  |  Print  |  Notify Moderator
The water in the toilet bowl leaks past the trap and down into the tank. As a result, I am getting some smell coming up from the tank. I have used a coat hanger to dig around in the slot where the cap slides into to make sure there is no "debris" in there causing it to not seal correctly. That did not fix the problem. Any ideas on how to remedy this short of installing new seals? Any good recommendations for something to pour/squirt in there that might help a "dry" seal expand and seal better? Thanks in advance.
1997 Bounder 36S on F53 Chassis
1992 Geo Metro Toad
sharker6
Shelbyville, Kentucky
Posted: 05/28/08 11:50am Link  |  Quote  |  Print  |  Notify Moderator
Clean the seal by hand with a paper towel and cleaner. Then apply a coat of petroleum jelly to the complete seal. That will help if the seal is still fixable.
2005 Xterra off road 4X4, 2007 26' Aluma-Lite, WD w/ friction sway, Prodigy, Yamaha EF2400, 400w inverter, front carrier w/ rod holders, Dish Network
Joy
Henderson KY 42420
Posted: 05/28/08 11:55am Link  |  Quote  |  Print  |  Notify Moderator
Thetford has a cleaning liquid gel type product that works very well to really clean the ball & seal. There is a tool that looks sorta like a toothbrush with very stubby, coarse bristles on a slightly bent end. You put the cleaning stuff in the bowl, let it set a few minutes, then scrub every surface you can reach - top, bottom, under, over, around - with the brush then flush & rinse. Ours had been leaking for a while - Tiffin gave me this stuff and it worked first time. It doesn't take much to interfere with the seal - a couple of bits of TP will do it, even.
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Katie-Mini Aussie
Sam-Calico Fat Cat
Maggie-Chihuahua
2003 38'Phaeton DP
2006 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
Ames
South Central Florida
Try cleaning with an old tooth brush and soap and water. Be sure to scrub all parts well to remove any build up. Be sure to discard old brush so no one uses it to brush anything else.
Richard and Babs and a Bob Tail Cat
97 Beaver Patriot 40 Kitchen Slide
330 HP Member FMCA, BAC, Good Sam, CAT RV Club
Toad 04 Durango HEMI
Cloud Dancer
San Antonio and Livingston TX USA
Posted: 05/28/08 11:59am Link  |  Quote  |  Print  |  Notify Moderator
I always make sure I have a package of hobby sticks (from Hobby Lobby), and I use toilet bowl cleaner (the strong stuff, with acid). I pour about a cup of cleaner in the toilet and let it sit for a few minutes in order to break down mineral deposits (limestone, around here). I wrap a little bit of cotton cloth around the stick (previously called Popsicle stick) and scrub inside/beneath/on top of the rubber seal. I repeat the process one time. If that doesn't work,....replace the seal. It's not a difficult job.
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
Jerrybo66
AZ
Posted: 05/28/08 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
When not in use I spray some 303 on the seal. It stopped leaking...
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
DebDav
SE TX
Posted: 05/28/08 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a Sealand toilet they sell a cleaning kit. It consists of a tool that looks like an emory board. With the ball closed slide the tool between the ball and the rubber gasket. Scrape back and forth all around the ball. Yes, you can see the part of the ball when the ball is activated. You cannot see the sides. Multiple scraping and lots of water helps.
I took mine apart and found the sides were crusty. Cleaned with scraping and VOILA toilet holds water.
You may want to dump first then put 5 gallons of fresh water in and one deodorizer of your choice. Or position a fan above the toilet and blow into the bowl. Fumes will go out the vent stack.
DebDav
93 Prevost H3-40 - converting
Peg Leg
Anderson, IN
Posted: 05/28/08 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Call NASA, they have a toilet problem at the International Space Station. They have a shuttle mission scheduled for a Saturday launch. Talk about Plumbers overtime, I wonder if there will be a fuel surcharge.
Oh yeah, the problem is in the Russian built part. I don't think they've been using indoor plumbing that long. Anyone have page 347 of the 1968 Sears and Robuck Catalog, probalby got flushed already.
KA9ATV
K2500 7.4 3.73
Michelin 245/70R19.5 XDS2 on Vision Type 81's
31' Dutchmen
Yamaha EF3000iSE
retired gadgetman
Doug and Cassi Glass
Clifton Forge, VA
Posted: 05/28/08 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
I use plumbers silicone on mine occassionally.
Happy_Trails
Fulltime, USA
Posted: 05/28/08 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
We use silicone on the seal from time to time, keeps anything from sticking.
