bingoldsby
Oregon State Parks - somewhere
Although, my toilet is far older than yours, I did the petroleum jelly thing for some time. I had to keep re-applying it. Finally I just broke down, removed the toilet, and took it in to have the valve assembly replaced. (I also had to have the water fill valve replaced).
After that, the thing holds water just fine.
Brian K7ZRZ
Campgrounding hosting - Oregon State Parks
1987 30' Holiday Rambler Class A
GL1800 Goldwing - Honda Scooter Mounted
2000 Silver Miata LS Toad
Picture taken at Salem, Oregon
Wherever I happen to park
The approved procedure involves latex gloves (Follow haz-mat procedure) and some material to clean the seal with (Toilet paper?) Turn off city water, Turn off water pump, Step on flush pedal, Clean underside of seal, release flush pedal and clean ball or slide As others have said lubricate (Long list of lubricants suggested, Silicon sounds as good as any to me, Vaseline is another I've heard but that's petrolum jelly and don't necessarly mix well with rubber)
When finished remove gloves following Haz-mat procedure (Clean to clean, dirty to dirty) turn inside out and seal in a plastic bag for disposal
rebel462
ontario canada
Something I use is a bottle of dish soap the kind from Walmart that is EV friendly,it has a push down spout on top. Every now and then a small drop of the dish soap in the bowl will help keep the ball lubricated.I keep the bottle in the bathroom as it works great for your hands also.
RichNewcome
Fairmont, WV
Our Thetford will leak unless we let it close rather smartly. Releasing the pedal easily seems to keep it from sealing properly. It is kind of annoying to hear it slamming shut when someone uses it in the middle of the night.
Jakeman97
Florida / Massachusetts
kplender,
A petroleum base product will deteriorate your rubber seal even more in a very short time . I use this product Magic Lube on all my rubber seals. It has a Teflon Base and is just what the doctor ordered. Got mine at a plumbing supply store. Best of luck.
SidKaye
Mt Dora Florida, Montreal QC for the Summer
Cleaaning is good BUT your problem MAY be resolved by snugging up the "closet bolts", the two bolts that tighten the toilet against the rubber "doughnut" gasket creating a seal. Free & Easy to do BUT, Snug NOT Tight.
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, Hughes Direcway HN7000S, Satmex5,
http://www.kayepics.com
Texans
Try soaking with a vinegar solution, ours evidently had a mineral build-up and this cured it where scrubbing would not. Richard
Richard and Annell,
03 35' Dolphin (Workhorse W22), 02 4x4 Tracker,
Brakebuddy
gswcgi
Reno, NV
Had the sme problem so I started with the bent clothes hanger routine then put transmission sealer in the bottom of the bowl and let it sit for a day. No more problem!
'03 Safari, DP, 36" Nissan 4X4 toad
7th Cav
Someplace
If I just run the toilet brush around the seal at the bottom when it leaks, seams to work for us. Make sure that you get the bottom of the seal. No big hazmat issue.
7th Cav
2004 Damon Intruder 350
Workhorse W22
1997 Ford Explorer Toad
Tenn Stud
Northeast, TN
MY 2 cents. Just pour about 3/4 cup of cooking oil, Let it sit as long as you can. The oil will soften the seal. I have been camping since the very early 60's never replaced a seal yet. I use 1/2 antifreeze 1/2 cooking when winterizing works great
