RV.Net Open Roads Forum: General RVing Issues: Need security camera to catch vandals
 > Need security camera to catch vandals
sirdrakejr
Las Vegas, Nevada
Posted: 06/06/08 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from 5th wheels to Gen'l RVing Issues.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
dchuntnevada
Nevada
Posted: 06/06/08 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
The Hunting/game cameras are great, some have good night visibility and most have internal power sources. If you put it in a visible area your next thread will be who stole my camera
daytona7
Posted: 06/06/08 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
Forgot to mention. If you plan to use those 2.4Gh camera's, check to see if anyone in your area is also using one. Tried to use mine attached to my TV in an RV park in Florida but kept getting video feed from an RV about 200 foot away. He had his WalMart camera aimed to the empty site across from his MH and the power output would not allow my receiver to get anything other than his video.
Southwind85
Where I Park
Posted: 06/06/08 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
tvfrfireman wrote:
Just before leaving on our last trip I noticed that the safety latches on the awning were unlocked and the knobs were unscrewed. Upon returning from our two hundred mile trip I noticed that one of the four pins that holds the fifth wheel hitch in place had worked its way out and was missing the cotter pin.
Awning unlocked and unscrewed knobs are easy to do if you get distracted or are in a hurry. Knobs can loosen themselves and even fall out if they're only marginally snug.
As for the pin, that's a weird thing for someone to be messing with. I've heard of people pulling the 5th wheel latch to let you pull forward and drop the trailer into the bed. Did you check to verify it was secure and pinned properly prior to departure?
Pre departure and arrival checklists are good things.
The Good Life
sctusa
Carrabelle, Fl.
Posted: 06/06/08 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
fordsooperdootydieselsmoker wrote:
So I'm assuming from your post that a 40,000 watt electric cattle fence charger attached to your trailer is out of the question?
Grew up on a farm and they will get your attention, however no permanet damage. I made one out of a 12 volt car coil once and just hooked it to a 12 volt battery on a small charger. Tested it out by touching the wire where it terminated after about a mile run.
Darn near curled my toes!!
Scott
2005 Dodge 3500 4X2 HO CTD Dually 6 Speed
2005 Springdale 266RELL GL
Reese HP Dual Cam
Prodigy BC
2 Honda EU2000i's
2 Lifeline 31 Series AGM 12V RV Batts
2006 Harley XL1200R
SP 2610 GPS
26" Samsung LCD HD TV
wny_pat
Western NYS
Posted: 06/06/08 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
There is a Spy Store on Niagara Falls Blvd., Amherst, NY (just outside Buffalo). They have all kinds of neat stuff that you can touch and play with before buying. Surprised you don't have one on the west coast too.
TEXAS2STEP
New Braunfels Texas
Posted: 06/07/08 07:03am Link  |  Quote  |  Print  |  Notify Moderator
Tom_Kat is correct.
PattieAM
Maryland
Posted: 06/07/08 08:06am Link  |  Quote  |  Print  |  Notify Moderator
I wasn't towing at the time, but came out of the grocery store and thought my hitch looked 'different', sure enough, someone had pulled the clip off and taken the hitch pin - thankfully not the ball/riser, etc. I feel for your irritation.
