SOVINCE IN FLORIDA
For 5 years I pulled a nice Outback 21 RS (about 4300 pounds) with my F150 Crew (rated for 8000 pounds - TW). Needs have put me into a nice Mountaineer 29 (about 7600 pounds). I upgraded the hitch to the proper size (leveler bars and sway control) and put new tires on the truck. When I pull the new rig on the highway it feels like the suspension or steering is soft and there is a lot of wind effect push and some sway issues. I was thinking about upsizing to a 2500 series with a heavier suspension and harder tires. Do you think the change is necessary or do I have to get used to pulling a longer / heavier trailer ?
Hornet28BHDS
Parker, PA
I'd spring for the 3/4 ton.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
SemperFiCop
An F250 will work fine...
wcjeep
Tacoma, Wa
Avoid the Ford 6.0 diesel. Should be fine with Ford gasser, Duramax or Cummins.
Elmoclayman31
So. Cal.
Just up sized from a 1500 to a 2500 gasser. I drove the V10 Ford and to tell you the truth I wasn't impressed. I went with the 2500 chevy, 6.0L. If you can afford it spring for the 3/4 ton. It will give you much more confidence and just be a much more comfortable ride.
2007 Chevrolet 2500HD 6.0L
2008 26ft Thor Vortex
01 Suzuki RM250 (mine)
83 Yamaha PW50 (the boy's)
05 Roketa 70cc Quad (the princess')
Living my American Dream!
smkettner
What sway control do you have?
Did you put LT tires on the truck?
Have you weighed it to know where you are at including tongue weight?
JConatser
Smyrna, Tennessee, USA
SOVINCE IN FLORIDA wrote: ... I upgraded the hitch to the proper size (leveler bars and sway control)...
You need about 1000 lbs. tongue weight for that TT...is your hitch receiver rated to handle that much?
I'd vote yes on upgrading...3/4 ton will do just fine.
Ameri-Lite 24RB
1997 Chevy 1500 Ext Cab, 5.7L
Equal-i-zer Hitch
grantster
Beautiful British Columbia, Canada
Our F150 tows our 33' 6500 lb loaded Rockwood just fine, but I wouldn't consider it for your new Mountaineer, it's too heavy. A 3/4 ton diesel will work well for you.
DznyFan
Lorton, VA
I'm sure there are great deals to be had on 3/4 and up as well as diesels, new and used.
2006 Fleetwood Wilderness 3102BDS
2004 Excursion XLT 4x4 V10 4.30
Ride-Rite Air Bags | Air Lift SureSet
Hensley Arrow | Prodigy
Honda EU2000i Gennies
Garmin nĂ¼vi 350 | ScanGaugeII
_________________________________________
Me, the Wife & the Kid
