theprices
Lakewood, WA
I am new to this process, so this subject may have been discussed previously. If so, and you can provide a link that would be fine, or any direct comments. We have had a Class A motorhome now for 3 months, and I am getting it ready for a toad. I will be attaching something to the RV to protect the toad from dings. Any pro/con thoughts on a solid or strip type guard?
driveby
Vancouver BC Canada
Protect-A-Tow
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
chastho
arkansas
If you want to protect the toad get the protect-a-tow, it is a mesh fabric that attaches to the rear of mh and front of toad. The gravel shield on the rear of the mh will help some but will not stop all of the dings, protect a tow will.
ghamblen
Wilder, ID
Another vote for Protect-A-Tow. I don't know what type of MH you have but some DPs require some modification of the Protect-A-Tow to prevent the exhaust from burning a hole in the fabric.
Gary & Mary Hamblen
2006 Gulfstream Ultra LE 6316
2006 Saturn VUE
Roadmaster Sterling tow bar with US Gear Unified tow brake
xctraveler
Rochester, NY
Scroll to "Tow Defender"
I use this together with a solid rubber rock guard (which is next to worthless in protecting the tow'd)
Paul
Trucking down the road in a 2004 Southwind 36E on Workhorse Chassis with a 2005 Toyota RAV4 AWD stick shift tow'd with US Gear Brake System. Check out my journal
FMCA 352081
riggarob
Farmington, NH
You're talking about a full lengh mud flap, right? If so, go solid, the strips are******(experience) NOW, you also need a solid type protechtive shield that mounts to the tow bar on the toad, to get any kind of ding protection for the toad. Ours is from Blue OX, as well as our tow bar set-up. These have been on 3 MH's, and 2 different toads, and still working well. P.S. to all. Buy an MT/PT kit to check for stress cracks in the towing components. Good luck !
theprices wrote: I am new to this process, so this subject may have been discussed previously. If so, and you can provide a link that would be fine, or any direct comments. We have had a Class A motorhome now for 3 months, and I am getting it ready for a toad. I will be attaching something to the RV to protect the toad from dings. Any pro/con thoughts on a solid or strip type guard?
08 Fleetwood Providence 40X
FL-XC
US Gear Braking system
Blue OX towing system
06 Saturn Vue AWD toad
Wife and best friend Martha Baby
SweetPea - 15 year old "Maine coon cat" still mean as ever
Beware of those who point their finger the LOUDEST !
dbates
Marion, Indiana
Do a search under "Protect-A-Tow" & you will find 187 posts concerning it. Most all are very positive about the product. I've found that it not only protects the toad but keeps the MH rear end & camera very clean. It also is easy to hook up, remove & stow.
You don't say & your profile doesn't disclose what type of MH you have so if it is a diesel pusher with rear exhaust you can't use the Protect-A-Tow because the exhaust is too hot & can melt the Protect-A-Tow's fabric.
Dave
Plus New Brunswick, Prince Edward Island & Nova Scotia
wanderer72
Canada
Most definately Protect-a-Tow. click here for website
"A mind is a terrible thing to waste and a waist is a terrible thing to mind."
